I had picked up a body computer and traveler from a 1995 Lebaron convertible at our local Pick-n-Pull a while back. This was so I could use the traveler as the 1989 one needed a fuel flow signal. The 1990-91 SBECs do not produce this signal but rely on the data bus for this information. The BCM is the source for the data bus power.
Once I had it in hand and looked at it's various functions I realized it replaced the chime module, illuminated entry and courtesy light delay, intermittent wiper module, key in and headlights on warning as well as including an audible low fuel chime.
Since I had gotten the BCM and about 2 feet of the harness I decided to use as many of it's features as possible, eliminating the other modules. Everything work flawlessly as I was working on other areas, until about two weeks ago. I went to start the car and turn it around so I could evacuate and charge the AC system. Doors were locked (it also has the autolock feature) and the battery (new) was completely dead. I hooked up my battery charger on the 2 hour setting, and started some other items. The door lock/unlock relays started buzzing, so first thought was pull them, while I was removing them something in the body computer started smoking at which point I pulled the plug on the charger, smoke continued then stopped. I had pulled the negative cable off during this time. I removed the body computer and reconnected the battery and finished charging it. I opened the BCM case and found one of the transistors very much a crispy critter, but no other damage.
The original label with the PN is illegible and was when I got it, is there any way of telling which BCM it is? Second, does anyone have any idea what transistor would have been in the Q153 location?
Thanks.
Thanks.
