Welcome to Allpar. Park the Chiltons and Haynes and get the real service manual(s) for information. There are 2 volumes, one is Engine and Chassis (mechanical) and the other is Electrical/Engine performance (inc. diagnostics and wiring).
It will save you a lot of frustration, time and money. It will provide you with wire colors and harness routing. Some larger libraries may have them in the backroom stacks for loan or think of them as an important tool purchase. If you plan on doing your own work, they will become indispensable.
The turn signal switch feeds through the stop light switch so that the side opposite the direction that you are signaling will be your rear brake light. The hazard switch is battery supplied while the turn signals are ignition switch supplied. Two different circuits.
Sometimes the hazard switch contacts get oxidized from rarely being used and by rapidly cycling the switch on and off several times, it can clean the contacts and resume operation.
http://www.google.com/search?q=1984+chrysler+fwd+factory+service+manual&hl=en&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ei=9pgmUZ7GItGM0QHMpYDACA&ved=0CAoQ_AUoAQ&biw=1440&bih=768#imgrc=VsNLSxRd1YrdXM%3A%3B_gYadDmQavy2HM%3Bhttp%253A%252F%252Fwww.eautomobilia.com%252F%252Fimages%252Fdefault%252Fthumbnails%252FSMCHR84FWDELE_Large.png%3Bhttp%253A%252F%252Fwww.eautomobilia.com%252Fproduct%252F00%252FSMCHR84FWDELE%252F1984-Chrysler-FWD-Electrical-Engine-Performance-Shop-Service-Manual%3B500%3B500"]
http://www.google.com/search?q=1984+chrysler+fwd+factory+service+manual&hl=en&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ei=YKImUeG0IYi60QH6_4CYBQ&ved=0CAoQ_AUoAQ&biw=1440&bih=768#imgrc=LlWHFPq6XKQOXM%3A%3By3OIOYs2bTmkRM%3Bhttp%253A%252F%252Fi.ebayimg.com%252Ft%252F1984-Chrysler-FWD-Passenger-CAR-DAYTONA-LEBARON-NEW-YORKER-Service-Manual-%252F11%252F!B-fZsegCGk~%2524(KGrHqN%252C!h8EzLhURebNBM8w2r7Jww~~_35.JPG%3Bhttp%253A%252F%252Fwww.ebay.com%252Fitm%252F1984-Chrysler-FWD-Passenger-CAR-DAYTONA-LEBARON-NEW-YORKER-Service-Manual-%252F350417974009%3B218%3B300
