Hi y'all. Man, I was doing that power steering job and to get the pump in I unhooked that skinny little brake line that goes into the line that goes to the calipers or piston or wherever. Its right there to the right of the rotors up above a little bit. I can explain exactly which brake line it is if i need to, no problem. Anyway, after i got the line out of the way I got the pump in and hooked the little skinny line back up to the other skinny line. Well, I have power steering now but absolutely zero brakes. Its like they dont even build up when you push the pedal. Straight to the floor and I filled master, bled the side I took the line apart at and still no change. And, the e-brake is acting like its really weak now but I dont know if that was already like that or what because I never use it so cant remember it being like that if it was. I dont understand. I've had brake problems in the past. They would at least build up when I pushed pedal a few times. Never this. What did I do? Man this is not good. the money I saved on the power steering pump replacement looks like I may be using on a brake job?? I dont even think it will drive like other times I've had brake issues. Theres nothing. It goes straight to floor yet has fluid and bleeding the one side I unhooked the line at didn't even begin to change nothing yet. Hope I explained enough to understand the situation and hope someone has had this issue before or knows whats going on. Thanks a lotttt!
