Car platforms, architectures, and bodies
A new definition of "platform" and "architecture"
by "Triple T"
The old term "platform" doesn't fit the way FCA creates cars now; the computational power has moved engineering practices past that point. Now, each version of what FCA calls a "platform" (e.g. from 300C to Ghibli, or or Giulietta to Cherokee) is evolved; feedback from the performance of the final product and extensive customization is built in. The later the version of the car built from the platform, the more experience goes behind it.
The idea is to start from one point, and with that as a solid base, develop components and systems that match a new design intent. Each version should improve the "platform." At the same time, generally, items get cheaper as processes are worked out. If you start with an Alfa Romeo or Maserati, by the time it comes to Dodge, it will be ready for high volume (even if the Maserati started with a Dodge). And the same for the Maserati, some thing at first to expensive for a Dodge that will be affordable when scaled up.
There is a great deal of work done from the basic starting point. Going from one car on a platform to another is not just slapping another "top hat" on, as it may have been decades ago. You can use the engine bay and dashboard of the Chrysler 200 as your basic starting point, and turn it into a much larger, taller minivan.
What cannot be stressed enough, though, is that when a component or assembly is designed, validation and performance feedback is largely virtual; knowing how far the real parts deviate from the physical parts is invaluable, leading to shorter development time and better componentry - and the more variations on a platform are built, the more knowledge goes into them.
Architecture is exactly what the term implies - a thematic starting point.
The classic definitions
Retired product planner Burton Bouwkamp wrote: "We (Chrysler engineers) defined a platform by the horizontal and vertical dimensions from the centerline of the front wheels to the cowl (base of windshield) and to the H point (the hip joint). Said another way, the cowl position and driver position relative to the front wheels defined a platform. The K and E bodies were the same platform."
He added,
In general, we called it a different body if the windshield and the surrounding "A" pillars were different. A different platform had a different front track and a different position ("H point") of the driver relative to the front wheels. By these definitions, the M Body was on the same platform as the F Body; and if it had the same windshield and cowl, it was a stretch for us call it a different body.
Bob Sheaves wrote that this method continued until the use of CATIA, phased in around 1990 with the T3000/BR (1994 Dodge Ram) program; existing projects used the proprietary Chrysler CAD/CAM system, with the older platform definition, while new projects started with a definition of the platform as the suspension, driveline, and (the single most expensive component) the pan stamping, which was the floorpan and firewall.
At the same time, the platform's starting point was moved to one meter forward of the front wheel, rather than the center, to end the use of negative numbers.
In 1998-2001, the term was again redefined to exclude specific components, and referred solely to dimensions.
Bob Sheaves added, "By the logic some people express, such as the Prowler using the LH platform, one could also say the Viper was built from the Dakota platform, or the minivan shares the Neon platform." But, Bob continued, a platform is defined by a set of dimensions, not the powertrain, architecture, or appearance. Thus, the Plymouth Reliant was not on the same platform as the Plymouth Acclaim, though they have numerous similarities in other ways, and the Acclaim is based on the Reliant.
A platform only defines the space required to assemble the parts and nothing more.
A chassis is only the structural parts that attach the suspension, brakes, powertrain, steering, fuel, and ride control systems to the body.
- Bob Sheaves
This means that a Dodge, Fiat, and Jeep can have the same platform, yet have entirely different personalities. Parts sharing does not mean platform sharing, and platform sharing does not mean parts sharing.
The Reliant, 600ES, and Limousine, despite having major differences in appearance, handling, length, height, etc., were on the same platform (as defined at the time), and would be even if they did not also have very similar suspensions and engines. Very different vehicles can be on the same platform and very similar ones can be on different platforms - the first generation Neon and Stratus being an example of the latter.
As time went on and technology changed, new definitions were adopted. A platform is now defined as a collection of fixed hard points, so that different vehicles with the same points can be built on a single assembly line, with similar crash characteristics. This greatly cuts development costs and increases factory flexibility, so that the product mix can be altered very rapidly without additional cost as customer tastes change.
AutoTechnician added:
The platform is a set of dimensions. It dictates the physical maximum/minimum size some parts of the vehicle have to be in order to fit on the conveyors, lifts, jigs, etc... It dictates the locations of where various hardpoints have to be so the robots can grab, manipulate, machine and weld the various body parts and hoist components into place.
You could have two wildly different vehicles on the same platform, not sharing a single common component. If you had a sub-compact and a big mean solid-axle pickup truck on the same platform, and you'd be able to build them in the same factory on the same robots because the critical hardpoints and dimensions are the same.
The architecture is what goes inside those dimensions. That is the chassis, floor pan, body, engine, transmission, suspension, etc...I suppose in theory you could even have an architecture with hardpoints that could work on two different platforms (such a thing might be useful for flex purposes?).
All manufacturers have a platform, and an architecture. A lot of confusion occurs because not all manufacturers use the same terminology as Chrysler, and it gets compounded over language barriers where some words might not have an exact literal translation to English. I've seen Volkswagen engineers talking about what is clearly an architecture as a "platform" and vice versa from other makes. Just remember, in Chrysler-land [and at GM and Ford]: Platform = Dimensions, Architecture = Parts that goes inside those dimensions.
Definition of a beehive
Bob Sheaves wrote:
The wheelhouse opening is determined by cycling the suspension and steering, with largest available tire from the product planning group parameters, in what is called a "beehive" to determine the clearance zone for tires, chains (if specified), offset of wheels, etc.
