ok i could be nuts . at least thats how the service guys look at me !
i have 2010 rt classic 5.7 6 speed
it has 2400 miles on it as of today . i have been to the dealer over 4 times for problems that they cannot solve or are so common no one else notices but picky old me.
the problems are
1. ticking from the engine ,, they its air in the lifters,, they did a bleed procedure,,,i just drove the car 60 miles home and its still there,,
2. when shifting into 4th gear under hard accel theres a crunching or scrunch,, when u let the clutch out,. only into 4th .. is this normal
3. slight hesitations and lack of power intermitently,,, it stutters or seems to miss ,, never sets a trouble code,, seems to do it more when cold or warming up.. does it with traction control on or off..
are these common or am i toooo picky, ?? any body else have the same issues ??
its been this way since i bought it off the showroom floor.. ive gotten chrysler involved but so far in gettin no where,
also tonite when i got it home i noticed that when u rev the engine to 3000 or so and let it go back to idle the headlights will dim or slight flicker at the lowest idle point,, ??
and theres a slight vibration in the engine revving about 2100 -2300 it goes away at higher rpms and is smooth up to that point.
the ticking noise seems to be louder at listening behind the frt wheel under the car than under the hood ..
also , oil pressure is only 31 psi when warm at idle,,
looking for any feed back
any help would be greatly appreciated... its driving me nuts
Russ
the problems are
Russ
