1 - 4 of 4 Posts
I am looking for the hose from the charge air cooler to the throttle body for a 1990 VNT will be the length I need. It is going in a K body 2.2L T2 application using a 1990/91 air inlet system. I am using a two piece intake, so am not sure that the throttle body is the same location as the one piece.
Thanks!
Discussion Starter · #3 ·
5277797 is for the P body, I suspect since the K, G & J underhood dimensions are pretty much the same then I need the 5277796, but it would be nice to find the 5277795 also as it seems to be a metal and rubber assembly with no bypass nipple.
did you try "partsvoice.com" ??
1 - 4 of 4 Posts
