1 - 4 of 4 Posts
Hey I have two questions for a 89 Daytona Turbo II:
1. Can the charge temp sensor be installed in any of the two threaded openings in the intake manifold? Does it matter? The openings are next to each other.
2. Has anyone ever stripped the plastic threads on the charge temp sensor? Mine are..and can I dope it up with Teflon tape?
Thanks,
Jason
It should go into the throttle body, and I suspect it will be off in its reading if you put it in the intake manifold. You might get away with some threadlocker in its original location.
TII engine, not TBI.
Are you having trouble finding a replacement Jason....?
Discussion Starter #4
No I havent had the chance this week to install one. I did find one in my tool box. I installed a vacuum block so I had to swap the location of the charge temp and vacuum port.
Thanks
1 - 4 of 4 Posts
