1 - 6 of 6 Posts
This is my 2001 Cherokee, 4.0L with 206k miles. Every now and then I get a heat soak issue, where the Jeep starts but has no power. You can floor it, the speed remains near idle, then it slowly builds RPMs, then it’s fine. It’s so hard to recreate the issue. The stop has to be longer than stopping at the mail box, but less time than the dog park. I read an old TSB which said let it sit 10-20 minutes but I can’t consistently get this to happen.
So far, I’ve tackled the fuel side of the issue: new insulation between the manifold and fuel rail. For the heck of it I also threw in new Bosch 4 hole injectors. Boy is it smooth now - I’d recommend the 4 hole injectors to anyone with a 4.0L. I also changed the plugs, which looked good but had some eroded gaps. No two gaps were the same.
I guess the next suspect if it happens again is the crank sensor. Never set the CEL, but did have pending misfire codes, p0300, p0301, p0306.
Discussion Starter · #2 ·
Which design is older? The Jeep Cherokee XJ or the Goodyear Wrangler Radial? I think they may have finally stopped making this tire. These are 3 years old. Tread design and sidewall look unchanged from the 1980s.
Automotive parking light Wheel Automotive side marker light Tire Land vehicle
My son has a 2003 Jeep Wranger Rubicon with the 4.0 engine and 5-speed manual transmission.
Quite some time ago he had the same problem with heat soak (10-15 minutes after driving and parking in the summer heat) - with a misfire, hard to rev and a check-engine light with a misfire code.
There was a TSB that instructed the dealer (me......) to insulate several of the fuel injectors with a sleeve that had to be cut to fit. The part was available from Jeep and was very inexpensive. I did that for him, and he has not had a recurrence in many years.
I don’t have the TSB handy - but could try to find it if you think it would help.
Discussion Starter · #4 ·
Thanks! That’s basically what I read. I didn’t get the Mopar parts, but did put a new insulation pad and injector wrap. The kit had fuel rail wrap but I didn’t install it.
Reactions: 1999 White C5 Coupe
I didn’t wrap the fuel rail - but the Mopar insulation wrap / tube on the fuel injector (I think it was two of them per the TSB) worked.
Did you buy an aftermarket kit with all the supplies?
Discussion Starter · #6 ·
Yes, injector rail wrap, injector wraps, and a heat shield to place on top the manifold.
1 - 6 of 6 Posts
