1995, RAM-1500, 5.9, Auto, 2WD.
Had a miss in the engine a few days back and the Code suggested injector #6 problem. I pulled the lead and nothing changed so figured it was the problem and swapped for a new pone. All good, no codes, no miss.
About 20-miles later, Check Engine popped up, then a few seconds later it went off. I got to where I was going and when I came back tot he truck I thought I'd check the Codes and did the 3-key-trick and no Check Engine light at all.
It started and ran OK so off I went. The the Check Engine started flickering, I mean about 6-tmes per second flicker not flashing. I pulled into an Auto parts store and the key-trick showed a string of codes. I got the store to scan it and they got five codes.
Did the key-trick again and got 6 codes, well, 4 actual diagnostic ones.
Thanks
It would not idle but ran with a miss for a while then came good. When I got hm and stopped to open the gate it idled just fine and no miss.53 Internal PCM failure or PCM SPI comm failure
27 Injector # control circuit
42 Auto shutdown relay circuit
25 Idle air control motor circuits
34 Speed control circuit or speed control switch always low or high
Any thoughts on what's going wrong?12 OK
32 EGR Solenoid circuit
55 DONE
Thanks
