Chrysler's 2.0 Liter Engine (1995-2005) and "the first Neon"
The Chrysler 2.0 liter engine was first used in the Neon; it was also used in the export PT Cruiser, Plymouth Breeze, and Dodge Stratus.
Its ancestry can be traced back to the slant six, an engine known for its durability. The slant six and 2.2 liter "trans four" engines shared many common engineers and some design features.
The single-cam 2.0 gave rise to the DOHC engine used in the Neon, Avenger/Sebring, Mitsubishi Eclipse, and Eagle Talon small cars. It was also seriously considered by BMW for the 3-series (reportedly, dropped because American BMW owners objected). The 2.0 was the basis for the 1.8, the minivan-PT 2.4, and the 1.4/1.6 used in the first-generation BMW Mini. The final use of the engine family was in 2010, in the final PT Cruisers are made.
For development and design notes,
see our Neon powertrain development page
Designed and built by Chrysler, the 2.0 liter engine hit the ground running, with a well-balanced 132 horsepower and 129 lb-ft of torque - at a time when most
of its rivals failed to beat 100 horsepower. Even the Civic EX, with
125 horsepower (but 100 lb-ft of torque), couldn't come close to the Neon engine's torque. Gas mileage was good, given the power and weight of the
vehicles it was used in - except the 2000-2003 Neon,
due to unfavorable gear ratios.
See the Neon repairs for repair tips, and the Neon performance section for performance tips.
Dan Minick, a columnist for Automotive Rebuilder, pointed out:
The Mopar 2.0 blocks [SOHC and DOHC] have the same casting number. There may be machining differences for mounting. The SOHC cylinder head is only used on the 2.0 SOHC. The DOHC Neon
and 2.4 share a cylinder head with the 2.4; the Avenger, Sebring, and Eclipse 2.0
DOHC head is unique and has reversed flow.
The 2.0/2.4 uses the same bore and bore centers as the 2.2/2.5 four-cylinder, which it replaced.
There are quite a few similarities with the lower end of the block. However, the cylinder head of the
2.0/2.4 DOHC is an outright copy of the Mitsu 2.0 G63 DOHC, while the
SOHC version of the Chrysler 2.0 borrows heavily from Mitsu's early-90s
G15 1.5 colt motor.
A factory worker wrote:
The 1.8 liter export engine was based on the 2.0; it was a smaller bore, with the same rods and crank as the 2.0, but different pistons. The block line would change over the tooling for the smaller bore and run a few thousand per month, but you had to make sure there were no 1.8 blocks in the system afterwards - if you tried to bore out a 1.8 liter, rough-bored block to the 2.0 liter bore size, the tooling wouldn't take it. It happened a few times.
The Neon had the same 96 mm cylinder centers and the same bore as the 2.2 engine, with a shorter stroke to give it 2.0 liters of displacement, so it could share some tooling with the old 2.2. The engine had a shallow skirt to save weight, with a cast iron bedplate replacing separate bearing caps, adding stiffness. The combustion chamber had a pentroof setup.
Common repairs: head gaskets, coils, and engine mounts
For the 1995-97 models, the Neon head gasket typically lasted about 60,000 miles. Most buyers who called Chrysler got a new head
gasket for $100 or less. The new three-layer head gasket design was far superior, and one engineer said it was close to the originally specified design which did not make it into production. Symptoms of a bad head gasket are oil in the
antifreeze, oil on the engine, or antifreeze in the oil. (A
leaking valve cover gasket can also spill oil onto the engine, though
this is much less common). The revised (MLS) head gasket was
reportedly put into late 1997 and all newer models, eliminating the problem.
"Wheatking" wrote that the head bolt on the back outside of
cylinder #4 can bottom out on some blocks, so it doesn't exert
enough pressure on the headgasket to make a good seal; he claimed that grinding a few
threads off the bolt does the trick if it's leaking a little. "The new
MLS gasket is thicker than the old gaskets, one reason why it
works better."
The front and rear engine mounts tend to wear out on
manual-transmission Neons, with a lifespan of around 100,000 miles on average,
much less when racing. These are easy to replace or repair.
Some suggest adding window urethane to stiffen up the front mount,
which is more appropriate for racing than daily drivers but may be
handy for enthusiasts (the stiffer the mount, the smoother the shifts
but the more engine vibration is transmitted into the cabin). Many
people recommend Mopar Performance replacement mounts.
Early coils tended to fail early, resulting in a loping idle
and misfiring. The problem is barely noticeable but can hurt gas
mileage and power. Replacing the coil is a ten minute job.
Finally, the timing belt can skip a tooth, leading to poor
performance and gas mileage, as well as gurgling noises when driving
uphill with the air conditioning on.
Most of the following information is from Chrysler press releases.
Chrysler - Dodge - Plymouth 2.0 liter engine details from Chrysler
The cross-flow cylinder head was made of cast aluminum, with pent-roof
combustion chambers and four valves per cylinder. The camshaft was installed
axially, from the front of the head. Spark plug tubes were pressed into
the head and held with anaerobic sealer, sealing against the
underside of the cylinder-head cover.
Connecting rods and rod caps were forged from powder metal and
machined in one piece, allowing weight reduction through greater
dimensional control and eliminating the small-end balance pad.
After machining, a parting line
between cap and rod was scribed on both sides of the rod by a laser beam, a patented process used for the first time in the industry.
Pressure on the inside diameter of the rod end
then fractured the rod along the scribe marks. The uneven mating surfaces
provided perfect alignment during
engine assembly. The cap bolts were threaded directly into the shank of the rod, easing assembly.
Chrysler minimized weight by using cast aluminum pistons with a shallow crown; pins were held in place by a press fit in the rods.
The cast iron block was 8.35 inches (212 mm) high, and ended at the centerline of the crank shaft; the top deck was open to cut weight. The crank was supported by a bedplate under the block, made up of a perimeter wall and
transverse webs, which also added structural
rigidity to the engine for durability and quiet operation. The bedplate, which also provided a flat sealing
surface for the oil pan, attaches to the base of the block.
Coolant flowed around all cylinders, and the water pump housing was cast into the
front of the clock.
Manifolds
The intake manifold was injection molded of 30 percent glass-filled
nylon, which provided a far smoother air path compared with metal manifolds, while slashing weight from around 9 lb to 4.1 lb (1.8 kg). It had 16.5 inch (420 mm) primary runners to optimize low-speed torque; they were curved to increase their length. One runner feeds both valves of each
cylinder. A tapered plenum and elbow section deliver air to the runners.
Manifold attachment points at the head included
compression limiters that assure proper sealing without damaging the
plastic material. The exhaust manifold was a compact, lightweight nodular iron casting
that allows exhaust gas to quickly heat the catalytic converter to
operating temperature for low emissions.
Valve Train
Powdered-metal valve seat inserts and valve guides were pressed
into the head. The intake ports developed turbulence in the cylinders to speed
combustion.
A
single, centrally-mounted camshaft set four valves per cylinder in
motion (DOHC versions used separate cams). Intake valves were 1.3 inches (33 mm) in diameter, exhaust valves
1.1 inches (28 mm). Valves had a 42° included
angle, exhaust valves rearward, intake valves forward; intake valves
were splayed 3.6° for clearance to the spark plug tubes.
The valve train could control valve actuation to 7200 rpm. The
camshaft was post-hardened nodular iron with three lobes per cylinder (two for intake valves and one for exhaust). The camshaft operated
aluminum center-pivot rocker arms with roller bearing cam
followers and miniature hydraulic lash adjusters above the valve tips.
Exhaust rockers were forked so they could operate two valves. The rocker
arms pivoted on shafts clamped to the head. The lightweight valves
needed only single valve springs.
The camshaft was driven by a cog belt, with extra strength to handle the load of operating 16 valves. A spring-loaded automatic tensioner with hydraulic damping
pushed an idler pulley against the back of the belt (it should generally be replaced with the belt). Low-inertia
sprockets of powdered metal were spaced away from the clock to
reduce the belt operating temperature. The belt is completely enclosed
by a two piece close- fitting molded plastic cover to keep dirt and moisture out.
Crankshaft and bearings
The modular iron crankshaft had counterweights on
both sides of each crank pin to balance the bearing rods for smooth,
quiet operation, and weighed 33 pounds (15 kg).
Counterweights straddling each crank pin allow smaller bearing
diameters, cutting friction. Diameters of the main bearings were 20%
smaller than past practice and diameters of the rod bearings
were 8% smaller.
A conventional inertia-ring vibration damper is mounted on the nose
of the crankshaft. The inertia-ring has machined-in pulley grooves to
drive the alternator and accessory belts. The damper minimizes engine
noise and vibration.
The camshaft operates directly in the cylinder head without bearing
inserts. The main and rod bearings have high-load bi-metal inserts.
Neon engine lubrication and cooling
The powdered metal gerotor oil pump was mounted in the front of the block,
and driven by the crankshaft. The block was inclined to the right (rearward in the car) to allow
the oil to drain easily from the head. Oil capacity was four quarts, plus filter, with SAE 5W-30 oil, grade SG/SH, recommended [many dealers at the time used 10W30]. Mounting the oil filter to an extension of the bedplate eased access.
The water pump was driven by the timing belt, and had a housing built into the block. A single molded plastic
unit was the combined thermostat housing, filler neck,
radiator hose nipple, and overflow nipple.
The thermostat had an air vent and a check ball that allowed air in
the coolant to escape when the system was cool, but seated with a tight
fit to assure rapid engine warm up. Allowing air to escape the vent
help prevent swings in coolant temperature during warm up, and made refilling the system easier because it prevented air
entrapment; it also prevented premature head gasket failure caused by bubbles in the antifreeze.
Sealing
Neon and other 2.0 engines were far more tightly sealed than the 2.2 that preceded them.
  • The crankshaft rear main seal used a Teflon lip and was pressed directly into the
    black-and-bedplate assembly, instead of into a bolt-on housing.
  • The oil pump cover also housed the crankshaft front main seal.
  • The oil pan and cylinder head cover gaskets were
    molded
    silicone with steel backbones and compression limiters; the oil pan drain plug had a molded seal.
  • The block bedplate and top surface of the cylinder head were machined flat for easy, precise sealing.
  • The spark plug tubes had individual molded seals.
  • A silicone-rubber gasket, molded onto the thermostat, created
    a high-integrity seal between the thermostat housing and the cylinder
    head.
Chrysler electronic fuel injection and ignition systems
The sequential multi-port injection system used four cone-spray
injectors; a slot in the top of
each intake port helped locate the injector, so fuel was sprayed into the intake valves.
The throttle body had a 2.05 inch (52 mm) bore on automatic-equipped cars; manuals had a slightly smaller throttle body (48mm). The throttle body
had a contoured bore in the off-idle area that limits the amount of air
flow to the engine at low throttle; the two throttle bodies were contoured differently so tip-in was greater with the automatic, providing greater responsiveness, and lighter with the manual, providing smoother shifts and better control. Using an automatic body on the manual car provided slightly more power at wide open throttle, at the cost of excessively aggressive tip-in which made smooth driving at low speeds difficult.
Fuel-flow control software in the PCM (powertrain control module)
cut driveline shock and oscillation from rapid changes in throttle opening. The fuel injection control software in the PCM adjusted the injection pulse duration for
the varying pressure differences between the fuel supply system and
the intake manifold.
The 2.0-liter engine had a direct ignition system (DIS) with crankshaft and camshaft sensors. The crankshaft sensor
sensed two patterns of four slots, each 180° apart, in the counterweight. The slots feed data for engine speed, while the positions on the crankshaft establish engine timing. Spark advance and injection timing were computed from
slots that were 20° apart; the "signature" slot was 60 degrees
wide while the others were around 5° wide. The sensor output
from the "signature" slot combined with the signal from the
camshaft sensor to determine the cylinder ready for fuel and ignition.
The camshaft sensor is on the rear of the cylinder
head, triggered by a ring magnet in the end of the camshaft. The
magnet's four poles are arranged at 150° and 210° intervals; their relationship to the signature slot is established in
less than one turn of the crankshaft, allowing injection to begin and bringing fast starts.
The four-lead direct-ignition coil pack was mounted above the cylinder
head cover, so only short secondary-wire leads were required, reducing cost and maintenance.
Engine Metallurgy
% stronger than
traditional drop forging
HS150HS160HS170
Ultimate tensile strength 1.0%6.6%11.6%
Yield strength18.3%19.9%24.7%
Compressive yield strength12.2%13.5%21.3%
Shear strength3.7%9.7%16.6%
Mike Volkmann, who provided the chart, wrote:
Powder-forged rods were made from one three mixes: 3Cu5C, 3Cu6C, 3Cu7C, all containing 3% copper, and 0.50%, 0.57%, or 0.64% carbon, respectively. (The Metaldyne trade names are HS150ª, HS160ª, and HS170ª.) For the 2.0 and 2.4 engines:
  • All 1995-1997 connecting rods are made from HS150.
  • All 1997-2005 DOHC (except SRT) and standard SOHC rods are made from HS160.
  • All 2001-05 Magnum SOHC and SRT are made from HS170; this mix is also used for the SRT V8s. The 01-05 Magnums have the strongest available rods available for a 2.0 engine.
A source from Metaldyne wrote that the 6.1 and 6.4 Hemi have HS150, not HS170, rods, and that there are five mixes for powder forged rods on the 2.0: 2Cu5C, 2Cu6C, 3Cu5C, 3Cu6C, 325Cu7C. The first two are 2% copper, the third and fourth are 3% copper, and the last is 3.25% copper. The carbon level is 0.50% for 5C, 0.57% for 6C, or 0.64% for 7C. The corresponding Metaldyne trade names are LS120™, MS130™, HS150™, HS160™, and HS170M™. For the 2.0 and 2.4 engines, this source wrote that all 1995-2010 connecting rods are made from LS120; the SRT V8s are made from HS150. The 2.4 Turbo (SRT) had Mahle forged steel connecting rods made with C70 material.
"Wheatking" pointed out that the 2.0 was the first American-produced engine to be used in a Japanese vehicle since World War II (before and during the war, Toyota used Chevrolet engines cloned so well the parts were interchangeable - in their copies of Dodge trucks, whose parts interchanged with the real thing).
SOHC Engine Specs (1994-99)
132 bhp (98 kW) @ 6000; 129 lb-ft (174 N-m) @ 5000.
Gas mileage in the 1995-99 Neon: 29 city/38 highway (with five-speed). Mileage in
the Breeze/Stratus and Eclipse/Talon was lower, due to added weight. Mileage varied in the 2000-2004 Neons due to different gearing; 2000-03 Neons, which used the old ACR gearing, had particularly poor highway mileage.
The 1995-99 DOHC produced 150 horsepower in the Neon and 140 horsepower in the Mitsubishi Eclipse and Eagle Talon (due to packaging issues, the manifolds were reversed on Eclipse/Talon).
Bore x stroke: 3.44 (87.5) x 3.27 (83) (Bore-to-stroke ratio -- 1.05:1)
Block height: 8.35 (212.0)
Rod length: 5.47 (139.0)
Connecting rod L/R: 3.35:1
Compression ratio: 9.8:1
Displacement: 121.8 cubic inches (1996 cc)
More 2.0 and related pages
