Chrysler CNG (Compressed Natural Gas) Vans and Minivans
Also see: electric minivans and alternative fuels
In 1991, Dodge started testing the use of compressed natural gas for full-size vans (B-vans), in both passenger and cargo versions. In a joint project with the Gas Research Institute, Dodge built 25 CNG vans, and placed 20 into service in private fleets, with five kept by the truck team.
In 1992, Dodge introduced its production-version full-sized natural gas powered van, with a run estimated at 2,000 vans. Built at the main Windsor assembly lines and transferred to an on-site conversion facility for CNG outfitting, they carried the standard 7/70 powertrain warranty, and were targeted to fleets. The range was 120 miles.
Two years later, in 1994, Chrysler's compressed natural gas (CNG) minivan was first brought out; all three short-wheelbase minivans could be purchased with a CNG 3.3 L OHV SMPI V-6 engine and 41TE electronically controlled four-speed overdrive transaxle. Operating cost with CNG was less than with gasoline, and emissions were far lower as well. The engine and fuel system were developed by Chrysler engineers and the vehicles were assembled by Chrysler. Warranty coverage on the vehicle and fuel system was the same as on gasoline engine vehicles, while emission levels conformed to California LEV (Low Emission Vehicle) standards:
Emissions limits in grams/mile at 50,000 miles; NMOG = non-methane organic gases (unburned hydrocarbons, except methane)
Fuel economy with CNG is roughly equivalent to that provided by gasoline on a energy content basis. Power is reduced approximately 15% from gasoline-fuel levels because CNG displaces more air in the cylinders, reducing volumetric efficiency.
The CNG fuel injection system used sequential multi-point injection (SMPI), a major step forward in responsiveness, performance and emission control compared to aftermarket conversions. Injectors and fuel rails were given a much higher flow capacity than gasoline injectors because of the lower energy content in CNG; the separate electronic injector-driver module was required to operate the high flow injectors. The control system included sensors for both fuel temperature and pressure to provide a correct basis for fuel flow; an oxygen sensor fine-tuned the fuel mixture. A specially formulated three-way catalyst assured extremely low emissions. Test procedures were inadequate to accurately measure the emissions from these vehicles, but they were the lowest emission levels of any vehicles available to the public at the time.
Fuel was stored in four glass and epoxy-wrapped aluminum cylinders. When filled at 3000 psi they held the equivalent of 8.5 gallons of gasoline. Two tanks were under the floor, replacing the gasoline tank. The other tanks took the place normally occupied by the spare tire. The spare was stored inside the vehicle. Fuel was supplied to the engine by pressure in the tanks, rather than by a pump. A regulator at the tank maintained a constant operating pressure. There was no return line from the engine to the tank.
The cylinders were recharged at a CNG refueling station through a quick connect coupling. At a quick-fill station this takes about five minutes. Slow refilling at a fleet garage could be done over night. A home refueling unit was also available. A conventional fuel gauge on the instrument panel sensed the amount of fuel remaining in the tanks by measuring its pressure. Regardless of the refueling system used, no evaporation or loss of fuel occurred.
To maintain durability with CNG, different materials were required for valves, valve stem seals and valve seat inserts.
Additional safety features included both ignition-activated and manual gas shutoff valves, back flow check valves in the refueling circuit, armored stainless steel fuel lines and fuel cylinders that meet rigid Department of Transportation requirements. Valve placement and mounting was designed to avoid damage in a collision.
The CNG minivans ran for a long time, albeit in small quantities each year. The first minivans to be certified as Ultra-Low Emission Vehicles in California, their production was apparently constrained partly by problems with getting sufficient supplies of tanks and other parts. In 1997 and 1998, Chrysler dropped entirely out of CNG vehicle production - not to return until 2012, when they created a new CNG package for Ram pickups.
Is there another CNG minivan in the future?
James Finck filed for a patent for FCA US in 2013, on a modular storage system for "a gaseous fuel." The idea is partly to hide the tanks under the floor - or even to be a part of the floor. The illustration uses a minivan image and the text references minivans. The tank assembly, with a cover that doubles as a floor, fits just forward of the spare tire.
In addition to saving space, making a modular system would allow it to be built elsewhere, achieve certification, and then quickly be fit into a vehicle on the assembly line. The container could store more than one tank, of different sizes if needed, and could have different shapes. Thus, it could potentially be used in pickups as well.
While most minivan buyers have no desire for CNG, not having facilities to fill the tanks, fleet buyers may be attracted by the low and relatively steady price of the fuel, as well as its clean-burning attributes.
Sources: Steven St. Laurent and the U.S. Patent Office
Main minivans page • Electric minivans • Alternative fuels
2017 minivans
2011-16
2008-2010
2001-2007
1996-2000
1991-1995
1984-1990
Forums •
Reviews •
Electrics •
CNG
Repairs and performance •
Engines •
Firsts •
Factory
Home •
Engines •
Reviews •
Chrysler 1904-2018 •
Upcoming •
Trucks •
Pollutant | NMOG | CO |
Minimum standard | 0.5 | 9.0 |
LEV standard | 0.1 | 4.4 |
Reduction | 80% | 51% |
2017 minivans
2011-16
2008-2010
2001-2007
1996-2000
1991-1995
1984-1990
Forums •
Reviews •
Electrics •
CNG
Engines •
Firsts •
Factory
Home •
Engines •
Reviews •
Upcoming •
Trucks •
