Chrysler Fault Code 36: solenoid open or shorted
  • For Turbo cars, code 36 is triggered when the wastegate control solenoid circuit is shorted or open.
  • For multiport fuel injection cars which are not turbocharged, code 36 is triggered when the air switching solenoid circuit is open or shorted.
  • For Turbo IV VNT engines, code 36 is triggered when the #3 vent solenoid circuit is open or shorted.
In each of the above cases, this happens when ECU doesn't sense near 0vdc or 12vdc when the solenoid is turned on or off. When code 36 is thrown the power limited light will not be lit and the system does not enter limp mode.
Possible Reasons for Fault Code 36
Poor wiring or connection - Read the page 'How to troubleshoot drivability issues'. Check the wiring and connections from the logic module to the solenoids. Clean and re-grease the connectors with dielectric grease.
Defective solenoid - The solenoids are located in the right, front fender in a cluster of up to 4 solenoids. If a signal from the harness to the solenoid measures 12vdc when the solenoid is off the solenoid will need to be repaired or replaced. See Solenoids-101 for information about how solenoids work and can be tested.
