Chrysler Fault Code 47: Battery charging voltage out of range
Code 47 is triggered when the engine has been running more than 6 minutes, the coolant temperature is above 160 degrees, the engine is running above 1500 RPM, and the charge voltage sense input is less than one volt above the target voltage for 20 seconds as sensed by the computer. When code 46 is triggered the power limited light will be lit and the system will not enter limp mode. When the charging voltage returns to the target voltage the power limited light will go out but the code will still be stored.
Possible reasons include poor wiring or connections (see 'How to troubleshoot drivability issues', check the wiring and connections from the logic module to the power module, and clean and re-grease the connectors with dielectric grease); or a defective voltage regulator circuit (see Diagnosing Your Charging System).
