What is coming soon....some interesting stuff to post here.
Minivan - patent 6,905,155
Multiple height load floor system -In a motor vehicle having a cargo area over an in-floor recess for storing a spare wheel and tire, a multiple height load floor system for covering the in-floor recess provides the option of selecting the depth of the recess. The floor system is adapted to allot a lesser volume to the in-floor recess for use with an undersized spare, or a greater volume when a full-size spare is provided. In a motor vehicle with folding seats, the folding seats are selectively raised or lowered to align with the upper surface of the load floor system in its selected position, in order to present a substantially flat surface for carrying cargo. The selective raising or lowering of the seats and the floor system can be achieved through manually actuated or electrically powered mechanisms
Trucks - Patent 6,905,162
Truck cargo box enclosure - A tent enclosure for a pickup truck cargo box includes a pair of support tracks mounted to the side rails of the cargo box, a number of flexible support rods connected to the support tracks, and a fabric siding spanning the support rods and connected to the support tracks. The flexible support rods can be made up of multiple sections linked together, and, being longer than the width of the cargo box, describe an arch when connected to the support tracks. The forwardmost support rod can be secured to the truck cab. The fabric siding includes a U-channel edge for engaging the support track on each side of the cargo box, and is stretched over the support rods. The tent enclosure includes a door assembly for the end of the cargo box, which may be formed of fabric and integral with the fabric siding.
Engines - Patent 6,895,919
Even-firing, fully balanced, V-twin engine - A V-twin engine includes a two cylinder reciprocating apparatus, having a pair of connecting rods joined to a crankshaft through a pair of connecting rod journals that are centered at a common throw radius from the crankshaft axis, and angularly displaced from one another along the throw radius by an angular displacement equal to an included angle defined by axes of the cylinders, so that the pistons will move in unison and each reach top dead center (TDC) and bottom dead center (BDC) in their respective cylinders at substantially the same time. The cylinders fire alternately on sequential rotations the crankshaft. Counterweights on two balance shafts rotate in a 1:1 rotation ratio in a direction opposite to the crankshaft, with forces from the balance shaft counterweights and a crankshaft counterweight alternately aligning and opposing for counterbalancing vertical forces and unbalance loads in the engine.
Jeep - Patent 6,890,014
Conversion vehicle - An apparatus is provided for enabling the enlargement of the cabin for a vehicle having an enclosed cabin and a cargo bed extending rearwardly from the cabin. The apparatus includes a rear wall removably coupled to the cabin. A guide element is positioned along a floor of the cargo bed and a base portion of the rear wall is slideably coupled to the guide element, which enables the rear wall to be translated rearwardly from the cabin to vary a volume thereof.
