1 - 2 of 2 Posts
Our computer has a mind of its own. Right now we are waiting for the defroster to work...maybe a fuse?? We always have trouble starting it..u start it an it keeps dying...mechanic says something to do with security...any ideas?
Welcome to Allpar. Any fault codes? There may be fractured solder joints on the instrument cluster circuit board that may be causing hard/no-start issues. If the cluster is removed from the dash and the solder joints re-flowed, it usually fixes this.
The rear window defogger would be a separate issue. Does the yellow indicator come on? Check the fuse and for power at the rear glass grid.
P.S. - Are you getting a start/stall condition or flashing headlights like a Security system (VTSS) activation when starting the vehicle? Any computer replacement history?
1 - 2 of 2 Posts
