Chrysler Technological Innovations: The Big List of Chrysler Firsts
Also see: New technologies • Alternative fuels and such
Chrysler Corporation/Maxwell Motors has been responsible for many more innovations than one would expect, particularly in the early years, when Carl Breer was seeking out and developing new technologies. In the 1970s, many innovations were driven by the rocket scientists at Chrysler Huntsville Electronics.
The First Chryslers: the Zeder-Breer-Skelton cars
The 1934 Airflow was the first car to use scientific weight distribution and synchronized front and rear springs for an anti-pitch ride. The Amola-steel body provided most of the structural strength.
Former Chrysler owner Daimler claimed to have invented both the car and the truck. While Gottlieb Daimler did create the first car with a working internal combustion engine, he was decades too late to invent the car. Nicolas-Joseph Cugnot did that, in 1769, building self-propelled vehicles with steering and brakes, mostly as trucks, all steam powered.
The Encyclopedia Britannica and other sources credit Cugnot with inventing the car. (Mercedes also holds claim to the first antilock brakes, only a few years after Chrysler and Jensen had started using them.)
Chrysler started using one-piece flat windshields with their 1925s, as did Chevrolet and Studebaker; none scored a "first" and Chrysler went back to split windshields a few years later.
The 1950s and 1960s
RADIO DAYS: CHRYSLER AND AUTOMOTIVE AUDIO
Modern times
Duane D. Hughes added:
Chrysler popularized digital dashboards, starting with the 1981 Imperial;
the one above is from a 1985 Dodge 600ES.
Automotive development: Pioneering CAD
Russ Shreve wrote that the Valiant was one of the first cars to have its suspension tested for loads and stress by computer. Computers cut development time by testing parts electronically, rather than by hand. Designs not failed by the computer were then built in prototypes.
The Valiant was one of the first vehicles to be tuned for lower noise by computer. An October 1959 magazine said that "the Valiant may well be the quietest small car ever made."
Adopted innovations
The 1996 Grand Cherokee allowed owners to easily set preferences such as whether the horn honked on locking and the doors locked at a certain speed. Patent application 152968 by Kevin Schwanz, David Pruett, and Tracey Stanyer covers a means of accessing the computer via a standard serial interface (RS-232) to retrieve information and change settings. Chrysler has usually used, from their 1980s fuel injected engines to current models, a system which lets ordinary people access error codes.
Credits / key
BWBill Watson DDH Duane D. Hughes DP Dave Pope
Also see Moving to front wheel drive • New technologies • Alternative fuels and such
What are we missing? Let us know!
Home •
Engines •
Reviews •
Chrysler 1904-2018 •
Upcoming •
Trucks •
- Overdrive. The "fourth gear" using the Keller clutch was invented at Chrysler, but to avoid tooling costs, Walter P. Chrysler had Borg-Warner supply it; competitors could also buy it (Breer, p. 124)
- Bonderite painting process (removed oil from body panels prior to painting)
- Replaceable-element oil filter (1924). In 1961, oil filters were still an option on some Chevrolets; they became standard on Chryslers in the 1930s.DDH
- Four-wheel hydraulic brakes (1924)
- Based on a system created by Lockheed, four-wheel hydraulic brakes had to be completely redesigned by Maxwell/Chrysler engineers. Earlier, Duesenberg had a hydraulic brake system on a handful of cars; Rickenbacker had used hydraulic brakes, but they were unreliable and limited production.
- In-car temperature gauge (most people bought MotoMeters, which replaced the radiator caps, before then); 1924
- Three-tone paint job (on roadsters; 1924) - thanks, Scrounge
- Rubber engine mounts as part of a system to stop engine vibration (1925) (Others had used rubber engine mounts, but not as part of an engineered, researched system, which was far more effective)
- Rubber spring shackles (1926BW)
- Adjustable front seats (1926BW)
- Full range crankshaft impulse neutralizer and vibration damper (1928) - used today on all (or nearly all) cars
- First production use of downdraft carburetors (1929)
- Rust-proofed fenders and other sheet metal parts (1929BW)
- Automatic spark control, centrifuge and vacuum (1931)
Meet the early heros of Chrysler Corporation, the "Three Musketeers," the designers of the first Chrysler car: Fred Zeder, Carl Breer, Owen Skelton.
Floating Power (1931): Bill Watson wrote, "Positioning the front and rear engine mounts with the engine's centre of gravity mid-way between the two. Thus, with rubber engine mounts, the engine could rock on the axis."- Roller bearing universal joints (1932)
- Automatic choke (1932) - Oldsmobile also produced an automatic choke on their 1932 cars. Carl Breer gave credit to the Sisson Company for working with Chrysler on this; they gradually opened the choke with a bi-metal thermostat control, the same basic setup used into the 1980s. "Later, we applied controlled exhaust heat to the mixture during the initial running to help shorten the warm-up period."
- Exhaust valve seat inserts (1932) - made of tungsten alloy
- Power hydraulic brakes (1932)
- Plastic steering wheels (1930s) for safey - prevented the driver from being impaled on the steering column and did not splinter (developed with the Dryden Rubber Company)
- All helical geared transmission (1933) - replacing "spur gears"
- Safety-rim wheels (1940DDH) so that tires would remain on the wheel even after a blowout; they quickly became an industry standard
- Rotor type oil pump (1940DDH)
- Two-speed windshield wipers (1940)
- Two leading shoe front-wheel brakes (1940DDH)
- Ignition-key starting (instead of turning the key and pressing a button; 1949DDH)
- Popup (hidden) headlights in a mass-production vehicle (1942 DeSoto, following the not-actually-mass-produced 1936 Cord)
- Resistor spark plugs, standard, to avoid radio interference (1949DDH)
- Rubber-isolated steering gear (1938)
- Padded dashboard (for fewer injuries in collisions; 1949; thanks, J. Mutz)
- Splash-proof ignition system (1949DDH)
- Station wagon tailgate window that rolls down into tailgate (1950BW)
- Bob Sheaves wrote: "The ball ramp idea [from the 1950 self-energizing brakes] was later used by Eaton and AAM to actuate their electronic locking differential. The balls could deform and jam; this was also an issue with the electric magnets to lock the differential side gears together."
- Four-wheel, self-energizing hydraulic disc brakes (1950)
- Water-jacketed carburetor throttle body; forced-air cooled brakes (1950)
- Full time power steering (1951 Chrysler). GM used one in 1952, but GM's had no assist until 3 pounds of pressure were applied to the steering wheel.
- Functional hood air scoop (1952)
The 1950s and 1960s
- First use of modern electronic fuel injection (1958 Electrojector; also the second American automaker's use of electronic fuel injection, 1981 Imperial)
- Solid state, no-tubes radio (1956 model year - 1955 calendar year - one year before GM claimed credit for the "first")
- First media-playing system: Highway Hi-Fi (turntable with special records; 1955 for 1956 model year)
DP - Search-tune radio with direct frequency entry (1978)
- Electronically tuned radios with digital clock (1984)
- First widely available automotive air conditioner: 1953 Chrysler New YorkerDP. The 1940 Packard had a modern air conditioner years earlier; Chrysler planned one before the war, but did not produce it.
- The Imperial Club wrote:
Mopar products used flush-mounted air intake grilles instead of scoops . ... the compressor took up only one cubic foot under the hood. ...
High was capable of cooling a big DeSoto or Chrysler from 120 to 85 degrees in about two minutes. Since Airtemp relied on fresh air, drawing in 60% more than any other system, it avoided the staleness of more primitive rigs. Instead of the awkward plastic tubes mounted on the package shelf, as on GM and other setups, Airtemp employed small ducts that directed cool air toward the ceiling of the car, the air then filtered down around the passengers instead of blowing directly at them.
- First American production engine with 1 horsepower per cubic inch: 1956 Chrysler 300B (355 hp, 354 cid Hemi engine) - before GM, which claimed credit DP
- Groundbreaking Torqueflite automatic, based on the Simpson gearset, launched (1956)
- Curved side windows (1957 Imperial)
- Cruise control: "Auto Pilot" (1958)DP. Bill Watson wrote: "Unlike later units, you set the speed on a dial located on the dash. If you hit the brakes, you had to start all over. It was used on full-size cars through 1966, when it was replaced by 1967's cruise with the controls on the turn signal arm."
- Swivel seats (1959; did not last)
- Automatic-dimming rearview mirror (1959 Chrysler)
- Electroluminescent instrument panel lighting (1960)
- Alternators - first car to have them standard in a civilian car (1960 Valiant); first to make them standard in all cars (US only, 1961)
- First American full line of passenger cars with unit-body construction: 1961
DP- "Full line" is meant as "entry level, upscale, and everything between," not "every car they made." Imperials stayed body-on-frame through 1966, likely due to their small volumes. Other automakers had built unit-body cars, but not with such a wide range of vehicles. Bill Watson wrote, "it still had a chassis frame... The first unit body in the design we are familiar with appeared on the 1941 Nash 600." Nash ended up as part of Chrysler via the AMC purchase in 1987. All Chrysler unit-bodies of the time, other than the Valiant, used a "stub frame" - not for structural support, but to make production easier.
- Cold-extruded axle shafts (1960)
- Axial flow blower for HVAC (1962)
- Four wheel drive with an automatic transmission (1963)
- Elemental tin used in cast-iron engine block (1963)
- Distributor vacuum advance control valve to slash emissions and raise gas mileage without side effects (1963)
- Tailgate window washer (1968)
- Chrome-plated plastic grille to save weight, money (1968)
- US use of auxiliary driving lights using quartz-halogen bulbs (1969; first seen in Europe in 1962)
- Four wheel antilock brakes (SureBrake) on the 1971 Imperial, introduced during 1970; though the first production car to have antilock brakes at all was the 1966 Jensen FF. (J. Mutz wrote that the 1967 Imperial also had rear anti-lock brakes.
Mercedes later claimed that its S-Class was the first production car with antilock brakes, in the late 1970s.) - Electronic ignition in all cars, 1973 (Studebaker used electronic ignition in 1965, but only on a single model. Chrysler beat every other automaker by several years in making it standard; they had started using their system in 1971.)
- On-board computers (1976 Chrysler Lean Burn). See the "Lean Burn" page.
- Hall Effect electronic distributor (1978)
- Electronic beam welding of aluminum die-cast intake manifolds (1978)
- Stamped aluminum wheels (1979)
- Standard radial tires on all cars (1979)
- Permanent-memory electronic display odometer (1981)
- Electronic Voice Alert (1983): your car speaking pre-recorded messages
- Modern cupholders (1983)
- Turbocharger with water-cooled bearing housing (1984)
- Computer-controlled charging system (1985) [Daniel Stern commented that this is debatable - it's a Chrysler claim but "All Chrysler did was move the
voltage regulator onto the boards inside the engine control computer
box."] - Post-hardened nodular iron camshaft (reduce friction, increasing as mileage, with roller followers, by 4%; 1988)
- Multiple access, arbitration-based communications network with non-destructive collision detection (1988)
- Electronically-controlled automatic transaxle (Ultradrive, 1989)
- Adaptive electronically-controlled automatic transaxle (Ultradrive, 1989)
- Direct-acting, ball-type solenoid valves for transmission shift control (1989)
- Electro-hydraulic, logic-controlled transmission switching valve (to allow one solenoid to operate two transmission elements and to prevent unintended application of one element)(1989)
- Four-wheel anti-lock brake system on a four-wheel drive vehicle (Jeep, 1989)
- Two-component mix-at-the-gun clear-coat paint system (1989)
- Variable-nozzle turbocharger for non-diesel car engine (1990, 2.2 Turbo IV)
- Optional cellular phone built into the driver's sun visor (1991; may have been a first, not sure; contrib. by Daniel Stern)
Modern times
- "Beehive" valve springs (1989 3.3). Paul Bunce wrote that Mercedes later claimed credit for these
- Standard driver side airbags (1988) and on all cars (1991)
- Crankshaft timing and camshaft reference sensors for distributeless ignition (DIS) (1989 3.3, for 1990 model year cars)
- Electric minivan (1993)
- Modular clutch and flywheel assembly (1993)
- Microprocessor controlled methanol concentration sensor (1993)
- Automatic transmission display based on shift lever position, confirmed with hydraulic pressure (1993)
- Cast aluminum front suspension upper shock mount bracket (1994)
- Customer programmable automatic door locks (1994)
- Single point sensor for air bag (1994)
- First use of "flash" reprogramming with vehicles's diagnostic tools (1994)
- Molded-in-color fascia with optimum gloss body color (1995)
- Tuned recyclable thermo composite intake manifold and air induction system (1995)
- Automatic transaxle with twin silent chains on phased sprockets (1995)
- All mechanical air bag restraint system (for the Jeep® Cherokee, 1995)
- Entire climate control system managed by the body controller (19 patents; 1993)
- Obstacle detection for powered sliding doors (2001)
- First factory-installed Bluetooth hands-free calling solution in North America (2003)
- Added exhaust braking to class 3-5 trucks (2007)
- World's first rear cross path accident avoidance system (2008)
- First minivan with blind spot monitor (2008)
- AWD system that disconnects front axle when not needed (for better mileage, 2009)
- Cloud-based voice recognition system for hands-free receipt of and response to text messages (2012)
- First light pickup with LED turn signals, marker lights, and tail lamps (2012)
- First AWD system with rear-axle disconnect (2013)
- Removable cowl plenum chamber (1996) for easier service of a tight engine bay
- Removable windshield wiper module (1996) for easier service of a tight engine bay
- Driver's side minivan sliding door (1996)
- Computer-operated air conditioning evaporator temperature control (1996)
- Seamless passenger air bag door
- Long-travel front suspension upper strut mount
- Electronic starter override (cannot activate the starter with the engine running)
- Positive temperature coefficient devices for wiring protection
- Unitized body (Airflow, 1934) - though Bill Watson wrote, "it still had a chassis frame. The frame was not as stiff as normal and the body framework was welded to the chassis to provide stiffness. The first unit body in the design we are familiar with appeared on the 1941 Nash 600." Nash ended up as part of Chrysler via the AMC purchase in 1987.
- There's been a lot of arguing about who made the first two door hardtop. Generally, the honor is given to Buick in 1949. Chrysler built seven in 1946, though (Town & Country) and claimed credit for this in 1995. At least one of these cars still exists. They also claim credit for the first hard-top convertible, 1946.
- Chrysler introduced hardened valve seat inserts in their engines around 1935. Other manufacturers let the valves close on a seat that was machined into the block or head. Up to that time, it was common for owners to have to have a valve job at 30,000 miles or earlier. The Chrysler engines, because of the inserts, were good for at least 80,000.
- Chrysler used a process called "Superfinish" on bearings starting in the early 1940s that decreased friction and increased the life of the engine. The Superfinish process reduced grinding marks to 1 millionth of an inch or less, so the Chrysler engines outlasted their counterparts from Ford and GM. Typical oil consumption for V-8 Fords of 1936 was listed in gallons, not quarts, in a Ford service manual. Chevy had only one technological advance in the "stove-bolt 6", overhead valves; otherwise, the engine was a throwback, using cast iron pistons, non-replaceable rod bearings, and splash lubrication. In contrast, Chrysler used aluminum pistons, bearing inserts, and full pressure lubrication. Details on this and hardened valve seats are in Carl Breer's book.
Adopted innovations
- The steering wheel (1898-1902) if you include Jeffery/Rambler (Packard also claims this)
- The first conventional (two wheel drive) trucks, 1910, if you include Jeffery/Rambler.
- Via Jeep, the first independent front suspension 4x4s and the first automatic-transmission 4x4s
- First full test course (Dodge Brothers)
- All-steel bodies, standard, across the line (Dodge Brothers)
- According to a 1973 Dodge brochure:
- The first four door sedan (1919)
- The first full (bench?) front seat (1921)
- Windshield washer/cleaner (1921)
- Industry first all-steel coupe body (June 1922, via Dodge Brothers)
Credits / key
Home •
Engines •
Reviews •
Upcoming •
Trucks •
