I can't help you, Max, because I'm not familiar with your vehicle. BUT, most of the time it's just a plastic housing around the lighter. It will either have screws in it or tabs that lock into the dash by pushing them in. Just use a plastic putty knife to pry the housing around it loose. You can use a flat tip screwdriver, but you may gouge the plastic by doing it that way.
