PASSENGER SIDE GLASS NOT OPERATING AS DRIVER SIDE DOES. HELP ME!
Try this procedure. It's designed for Mercedes cars but it's possible that the PT uses similar logic. Lower window all the way. Then raise the window all the way with the door closed and continue to hold the window switch in the "UP" position for several seconds after the window has reached the top.dave murray said:window should drop about an inch when opening the pass-door with top up
