Creating the second-generation Chrysler LHS and Chrysler 300M
4581 0
Land vehicle Vehicle Car Luxury vehicle Chrysler lhs
The Chrysler LHS and 300M shared a basic design with the Dodge Intrepid, Chrysler Concorde, and Eagle Vision - all were dubbed "LH cars." The main difference between the LHS and 300M and the other cars was in trim and length - the LHS was longer, at around 208 inches, while the 300M was shorter, at around 198 inches. The sporty 300M's shorter length was intended to reduce weight and to make it friendlier for European buyers; the comfort-biased LHS's greater length added trunk and seat leg room.
Development chief Burke Brown told Allpar, "Most spaces in Europe are five meters or so... That's why they had to shorten that back up. They called it the 5-meter car, and that's what the M car was built for, both US and European sales. It did well, I think."
The two cars were benchmarked against far more expensive cars: (we have verified the Audi A6, at least)
Chrysler LHSChrysler 300MBoth LHS and 300M
Lexus ES 300Lexus GS 3001993-1997 Vision and LHS
Toyota AvalonBMW 528 and BMW 740iNissan Maxima
Lincoln ContinentalBuick Park AvenueInfiniti Q45, J30, I30
Cadillac STSOldsmobile LSSMazda Millenia
Oldsmobile AuroraAudi A6Lexus LS 400
The standard, 250-horsepower 3.5-liter V-6 engine increased acceleration, while work to stiffen, strengthen, and refine the engine made it smoother and quieter. Platinum-tipped spark plugs and coil-on-plug ignition systems provided 100,000-mile scheduled tune-up intervals. Fuel economy was increased by lowering weight and reducing brake and aerodynamic drag. The two cars had different axle ratios, providing the 300M with 0-60 times of around 7.5 seconds, while the LHS was in the mid-8s (the larger car had better highway mileage).
Land vehicle Vehicle Car Luxury vehicle Sedan
Subtle revisions of the steering system, suspension, and tires improved the steering, handling, and ride, while cutting road noise; the cars still were tuned to provide more "road feel" than most full-size cars. The company tried to make both cars quieter by cutting engine noise, isolating the suspension, increasing body stiffness, and adding insulation. The suspension work included isolating the rear suspension cross member, and refining the front suspension and power train mounting cradles. Larger door weather strips and more accurate door fitting helped minimize wind noise; full-stamped doors provided a consistent sealing surface. See 300M and LHS noise, vibration, and harshness reduction.
Land vehicle Vehicle Car Luxury vehicle Full-size car
Body enhancements from the first generation included unique sill construction, with no outer skin, so each body had unique sill appearances using molded plastic claddings; standard quad headlamps; wind-tunnel-developed washer/wipers (with six individual body-mounted washer jets); and one-piece window opening moldings.
Inside, new seats had better comfort, support, and appearance, and a new defroster cleared the glass more quickly and completely. The radios and vent controls were improved, and the driver's floor mat was given a tie-down hook to keep it in place. Both LHS and 300M trunks used a new hinge linkage that did not intrude on useable space; the seat tracks had 8.7 inches (220 mm) of back-and-forth motion, to accommodate 96% of the United States' adult driving population.
LHS and 300M shared dashboards; the gauge pointers came to a sharp point at the end, favoring appearance over cost.
Land vehicle Vehicle Car Sedan Luxury vehicle
In addition to the obvious visual upgrades to the dashboard, a number of ergonomic changes weere made, including raising hte floor console armrest and moving it forward to match the door armrest; raising the left stalk and rotating its graphics toward the driver; making the trunk release button visible and easy to reach; putting radio and climate controls closer to the driver, while refining both (paying attention to button shames, labels, and tactile feedback); curving the tilt-wheel lever; and changing the steering wheel.
Burke Brown said the design was done by Tom Gale and Neil Walling, among others:
When we first started working on [the Concorde] we weren't getting enough cooling air, so the guys took a saber saw and started opening up that grill until we got enough air through it to meet our goals. Then we dressed it up a little bit and showed it to Tom and the guys. I remember looking at that and we thought, "He's going to say no way," and he looked at it and he said, "That kind of makes it. I like it." Cool, okay. We're good. It worked out really well.
As with the original LH cars, aerodynamics were refined, in this cases bringing the drag coefficient of both Chrysler LHS and 300M down to 0.310 - better than any Charger or Challenger to date. Designers and engineers worked together to provide good looks, low drag, and efficient engine cooling, with a rounded front end, carefully shaped lower fascia, gently flowing windshield pillars, sill cladding (to enhance air flow around the tires), and a tapered rear end; there were also subtle refinements in the cowl, mirrors, and windshield header to cut wind noise and control water flow.
Recreation Amusement park Games Vehicle Nonbuilding structure
Some of the changes made were using window moldings with little offset from the glass; fully stamped doors; a cowl screen to deflect the air over the wipers, and end washer fluid movement off parked wiper blades; water channels in the windshield moldings to keep the lower half of the side windows clear; and full-door-opening weatherstripping to stop roof water from entering open doors.
Attention was also paid to engine cooling, including changing the surfaces around the grille opening, putting slots in the cowl screen to send air over the engine mounts, removing part of the hood-to-cowl seal to cool the electronics there, adding louvers to the engine bay side panels (and enlarging the drive shaft and tie rod openings) to let air exit through the wheel-wells, improving the front air dam and fascia, adding a small tray by the radiator cross-member and powertrain/suspension cradle to force air out behind the engine (rather than coming back to the radiator), and adding baffles between the fascia and radiator support panel to force air through the cooling system.
Land vehicle Vehicle Car Sedan Full-size car
As for safety, new next-generation front airbags used smokeless inflators; head impact protection met 2003 standards; "radio keys" added theft prevention; the universal garage door opener used rolling codes; a "battery saver" system turned off exterior and interior courtesy lamps if the driver forgot; and the starter was blocked from operating while the engine was running. Not noted by Chrysler's press releases was a simple but unusual addition: dual brake light bulbs in each location, so that if one light burned out, the brake light was still be lit.
These steps all led to critical acclaim when the car was finally produced and sent around to reviewers. Some called the 300M the best big front-wheel drive car every made - all things considered.
In model-year 2002, the Chrysler LHS was renamed to Chrysler Concorde Limited. We have a review of this vehicle (the Concorde-named LHS), as well as the 1999 and 2001 300M and the 2002 Chrysler 300M Special.
Chrysler 300M pageMain LH cars pageChrysler 300M reviewChrysler 300M Special ReviewRepairs and Performance Upgrades
