Cummins 5.9 liter and 6.7 liter inline six-cylinder diesel engines
Section on 1989 adoption of Cummins engines in Dodge Rams © 2008 Curtis Redgap
Thanks to Harvey Barlow for updates/corrections. Updated 6/22/2015.
The long, happy partnership between Cummins and Dodge actually began long before the 1989 Dodge Ram pickup (Chrysler's first pickup with a Cummins diesel engine.) Indeed, it's possible the two companies would never have hooked up if not for Chrysler Europe - in particular, the former Commer/Karrier company, now owned by Chrysler and renamed to Dodge.
In 1959, Dodge started working on a new commercial truck; the company felt it had to use its own diesel to sell it, and it turned out that only Cummins would license their design for sale under the Chrysler name (full story).
Back in the USA, Dodge tried using Mitsubishi diesels in light-duty pickups during the 1970s, but they never caught on. Trying again with the big Cummins diesel was a risk, but it definitely paid off.
Part of the reason was that the huge diesel was completely different in character from the little Mitsubishi; designed for tractors, road graders, and such, the turbocharged Cummins "B" engine had entered production in late 1984. It was a relatively simple in-line design, with two valves per cylinder. Not long after production started (in 1985), engineers began adapting the 359 cid, or 5.9 liter, diesel for Dodge pickup trucks. It finally launched in Dodge Rams in 1989, rated at 160 horsepower and 400 lb.-ft. of peak torque.
The Cummins "B" engine had a 4.02 inch bore and a long 4.72 inch stroke to increase low-end torque. It had 17:1 compression, using an iron block with a steel crankshaft, assembled camshaft, forged I-beam connecting rods, and an aluminum intake manifold. The average first-overhaul time was nearly 300,000 miles, better than the Chevy and Ford V8 diesels by a good margin.
Engines for Dodge were built at the Consolidated Diesel Company in North Carolina; it was originally a joint venture of Cummins and J.I. Case, but Cummins later bought Case's share, so Consolidated Diesel is now the Cummins Rocky Mount Engine Plant. It has 1,900 employees, and exports engines to China (thanks, Walt Mercer). The plant was spotlighted by Fast Company some years ago.
The B was built with 18 wheelers in mind. Dodge had to make the truck work around the engine.
Dodge made an outstanding decision in choosing Cummins. Using an inline six, not a V-8, cut maintenance costs; it had about 40% fewer working parts than competitive engines. By the time Dodge put a pickup around it, its record was outstanding.
The long stroke of the 6 made serious torque, far more than the V-8s from GM (246 lb-ft) or Ford (345) at 400 lb-ft. It generated 160 hp at 2,500 rpm.
The engine was direct injected (fuel is squirted into the combustion chamber), unlike the two rival engines, so it threw off less heat, allowing a smaller radiator and less coolant.
Dodge engineered the truck to handle the expected longevity and power of the Cummins. Load carrying was 4,000 pounds above that of its rivals, right out of the box. A Dodge would cost about an extra of $2,043 to be equipped with the Cummins diesel. A good deal, and not overly done, but done just right. Dodge quickly saw sales jump for Cummins-equipped trucks.
The 1991 updates
In 1991, just two years after launch, several changes were made to Dodge Ram pickups with the Cummins diesel:
The redline was 3,000 rpm from 1994 through to 1998; the midyear-1998 24-valve engine raised the redline to 3,200 rpm, though by 2000 it was back to 3,000 again.
The 1991 updates
- The vacuum pump switched from dual-diaphragm to a vane type
- Two 750 amp batteries replaced the single 1,025 amp battery
- A new engine controller, SBEC II, was added; it controlled the intake manifold heater, wait-to-start timer, water-in-fuel sensing system, cruise, and transmission overdrive shift (on trucks with automatic transmissions)
- Midyear, an air-to-air intercooler was added to cut NOx emissions
- Midyear, the A518 four-speed automatic was used with the intercooled diesel, in Rams with a conventional cab
MTX BHP | MTX Torque | ATX BHP | ATX Torque | Notes | |||
1989 | 160 @ 2,500 | [email protected],700 | 12 valves |
