1 - 8 of 8 Posts
I had new struts put on the front of my 16 Dart GT a couple months ago and now notice a popping sound coming from the right front when I turn the car at low speed. It has never made that noise prior to getting the struts replaced.
Answers?
Does it do it at a standstill in Park (or Neutral with the parking brake on)? Pop the hood, place you hand on the top of the strut tower and feel for the popping noise.
Possibly upper mount bearings or the spring rubbing on sheetmetal inside the tower?
Reactions: AmbassadorSST
Discussion Starter · #3 ·
It does it when I turn the wheels at low speed...like when you turn the car around in a parking lot, when the wheels are turned the most.
I'll have to try that tomorrow. Thanks for the response.
Were those quick strut assemblies or new struts on your old springs and bushings? If the latter, I'd have to agree with IC that is sounds like a mount bearing. I suspect the reused the old ones and didn't put in new ones, like they should have. Another remote possibility is the half-shaft. Pretty coincidental if that's the case and I don't believe in coincidence.
Discussion Starter · #5 ·
Just the new struts on the old springs and bushings.
I had that noise on my old 97 caravan.
Was a bad sway bar link.
Yep, they'll make noise too. I'd still have them check the upper mount bearing.
1 - 8 of 8 Posts
