Looks pretty good, the little bar in the middle of the upper grill kinda throws it off a bit.....im kinda 50/50 on the hood, probably because its missing the scoop like the prior 2 SRT-4's![]()
LMK what you think! Open in new tab for a full res shot!
I think the viper style hood would look good on this car......Yeah, I took a little Neon SRT-4 flavor & added a little 2013 Viper to it as well.
Assuming that the GTS makes it to market.....they have already delayed the R/T indefinitely which the GTS was based upon. I wouldn't mind if they dont end up going turbo for the R/T that it at least gets bumped up to the GTS spec. 210 hp for an R/T sounds a lot better than 171 hp.yeah, but that's on the GTS, I doubt they'll use the same hood on the SRT.
184 horsepower. 171 ft. Lbs of torque.Assuming that the GTS makes it to market.....they have already delayed the R/T indefinitely which the GTS was based upon. I wouldn't mind if they dont end up going turbo for the R/T that it at least gets bumped up to the GTS spec. 210 hp for an R/T sounds a lot better than 171 hp.
Thanks for the correction, but still sounds better that having less tq than the 1.4T and 24 hp more. 50 hp bump and ~15 - 20 tq bump is much better for a R/T184 horsepower. 171 ft. Lbs of torque.
It'll make it to market, as Mopar parts packages. Stage 1 with the visual, and stage 2 with the performance chip etc. They wan't the R/T to be perfect when it gets off the line. "indefinitely" means un-defined. Most suspect the beginning (Jan/Feb) of the 2013 calendar year.Assuming that the GTS makes it to market.....they have already delayed the R/T indefinitely which the GTS was based upon. I wouldn't mind if they dont end up going turbo for the R/T that it at least gets bumped up to the GTS spec. 210 hp for an R/T sounds a lot better than 171 hp.
They said the same thing about the Mopar 200 Super SIt'll make it to market, as Mopar parts packages. Stage 1 with the visual, and stage 2 with the performance chip etc. They wan't the R/T to be perfect when it gets off the line. "indefinitely" means un-defined. Most suspect the beginning (Jan/Feb) of the 2013 calendar year.
