I am having some issues with the instrument panel lighting on my '75 Duster. The issue, I believe, is with the turn signal indicator lamps and the high beam indicator lamps primarily. When I activate my turn signals without my headlights of marker lights on, the left indicator seems to work fine, but the right indicator does not work at all. When I turn on the headlights/marker lights, left turn signal does not flash, but the high beam indicator lamp and the instrument panel backlight to the left of the speedometer flash. The right indicator still does not flash. When i activate my high beams, I lose the backlight to the left of the speedometer altogether, and my left turn signal indicator comes on and stays on (does not flash) except when I activate the left turn signal, at which point it flashes normally. Also, my high beam indicator lamp does not come on when I activate my high beams.
So, does all this craziness sound like it could be an issue with the wiring, or is it more likely an issue with the circuit board itself? If it is an issue with the circuit board, can it be repaired? Does anyone know who does this kind of work?
Thanks!
Thanks!
