As I am sure you are aware, the '62 Valiant's dashboard was a one-year-only design. I do have, and have consulted, the correct Factory Service Manual for the vehicle.
I need to extract the wiring harness going from the printed circuit board multi-connector to the bulkhead connector because it has become intermittent and I want to replace the wires. However, I can't see how to remove the harness without first removing the instrument cluster base from the dashboard. (I've already removed the instrument panel bezel, the printed circuit and instrument assembly and the lights, wiper and ignition switches.) How do you remove the instrument cluster base from the dash on a '62 Valiant?
Also, I can't figure out how to remove the speedometer from the instrument cluster base. I have disconnected the cable, but I can't find the 3 screws mentioned by the FSM at page 8-72. Would anybody know how to remove the speedo from the instrument cluster base on a '62 Valiant or Lancer?
Thanks very much.
Thanks very much.
