I got some interesting insider info today; I consider it to be reliable... Mopar isn't sitting still on their engine technology, nor are they giving up on the "old ways" either.
The new straight-6 - which will be hitting Jeep's first, it seems (Wagoneer?) - is going to have an all-aluminum block with NO SLEEVES. The block will have a sprayed-in piston lining that is honed down to its final size. This should reduce weight even further and also improve manufacturability. This jives with the previous news that this engine will replace and perform equivalently or better than the 5.7L - reducing weight is great way to increase performance. This tech isn't revolutionary, but it's primarily used by higher-end manufacturers such as Mercedes, BMW, and Audi. As far as I know, this is the first production use of this technology for Mopar. (All other aluminum-blocked engines have had cast-in sleeves.)
More excitingly, there appears to be a "big block" Hemi on the way still! A taller deck is going to be used to increase the displacement of the current engines. (An "RSB", if you will.) Final specs aren't set, but 426 c.i. is the target (for obvious reasons...) This engine has been hiding in plain sight, it seems; its code name is "Hercules". It seems the Gladiator concept may have been a bit of a smoke-screen or misdirection and less about the Jeep it rode around in than the engine that propelled it.
This does seem to conflict with the Rebel TR being shelved, but perhaps that shelving was temporary or this engine will see use in another model all together (like, say, the Gladiator). Regardless, this engine isn't dead just yet...This also bodes well for the Hemi line itself, IMO.
