Anyone know how to remove the inner half of the differential bearing on a 1988 Dodge Omni w/auto? I am not sure how to pull it as it is on a hollow shaft. This is the taper bearing that goes around the shaft where the half shaft enters the transmission/differential. I pulled the cover off to remove a leaking seal and noted that one of the rollers had fallen out of the bearing. The other half of the bearing in the cover I removed is scored up a bit. I am debating on whether to replace the seal and reassemble as is, or find some way to replace the bearing.
