Right/left is always the same, front/rear is usually different in olden times; now they often do something like same size front and rear, but higher performing brakes in front. The 1960s-70s were not great times for braking. There often was brake imbalance front/rear and it was not uncommon to have your rear wheels lock up, tossing your car around in a big circle. I suspect the poor brake balancing on RWD cars of that era vs the new FWD cars, which at least at Chrysler did have hydraulic brake force distribution (F/R, and on minivans, believe it or not, with a height adjustment - I'm probably using the wrong words, the correct ones are in the minivan book). Certainly the first car I had with high performing brakes was FWD... back then I didn't know about swapping wheel cylinders to compensate for lack of factory tuning. It is still a recommended process today - keep the existing brakes but change wheel cylinders so the correct brake force will be applied.
