Dodge Avenger Specifications
Did you want our main Dodge Avenger page? or the Dodge Avenger forums?
Dimensions are in inches (millimeters) at curb weight with standard wheels and tires unless otherwise noted. Gas mileage changes are due to the move to a new measurement system effective in model-year 2008. No manual transmission is available. Figures from the 2007 Camry are provided for comparison.
Available
Horsepower
Torque
2007 mpg
2008 mpg
2007 Camry Equiv.
2.4 liter
SE, SXT
[email protected],000
166 @ 4,400
24/32
21/30
158 hp; 161 lb-ft;
24/33 mpg
2.7 liter
Optional, SXT
189 @ 6,400
191 @ 4,000
22/30
19/27
3.5 (FWD)
R/T
235 @ 6,400
232 @ 4,000
19/28
16/26
268 hp; 248 lb-ft; 22/31 mpg
3.5 (AWD)
R/T AWD
235 @ 6,400
232 @ 4,000
17/26
N/A
The 2.4 liter goes with the 40TES automatic; the 2.7 V6 goes with the 41TES; the 3.5 with the 62TE.
Gear Ratios
40/41TES
62TE
1st
2.842
4.127
2nd
1.57
2.842
3rd
1.0
2.283
4th
0.69
Upshift - 1.452,
WOT kickdown - 1.570
5th
1.00
6th
0.690
Reverse
2.21
3.214
Final Drive Ratio
3.91
3.430
Overall Top Gear
2.70
2.248
<a name="_Toc129085061">Dimensions and Capacities</a>
Avenger2006 Stratus
Wheelbase
108.9 (2765.0)
108.0
Track
61.8 (1569.7)
60.2
Overall Length
190.9 (4848.5)
190.7
Overall Width
71.8 (1824.2)
70.6
Overall Height
58.9 (1496.4)
54.9
CdA
8.2
Cd
0.326
Fuel Tank Capacity, gal. (L)
FWD - 16.9 (64.0)
AWD - 17.3 (65.5)
Towing: 2.4L
1000 (450)
Towing: V6 engines
2000 (900)
2.4 / SE 2.4 / SXT 2.7 V6 3.5 FWD 3.5 AWD 2006 Stratus
Weight335534053465356837383250
Accommodations
AvengerStratus2007 Camry
EPA Total Interior Passenger Volume, cu. ft. (cu. M)
100.9 (2.857)
94.0
Front Head Room w/o Sunroof
40.0 (1016.9)
39
Front Head Room w/Sunroof
37.9 (963.4)
Front Leg Room
42.4 (1077.1)
42
Front Shoulder Room
56.4 (1432.8)
58
Front Hip Room
53.2 (1352.4)
55
Front Seat Travel
10.32 (260)
EPA Front Compartment Volume, cu. ft. (cu. M)
55.3 (1.57)
Rear Head Room
38.3 (972.3)
38
Rear Leg Room
36.5 (926.8)
38
Rear Shoulder Room
56.3 (1430.2)
57
Rear Hip Room
53.2 (1351.0)
54
Rear Knee Clearance
2.9 (74.1)
EPA Rear Compartment Volume, cu. ft. (cu. M)
45.55 (1.29)
Cargo Liftover Height
30.8 (781.9)
SAE Luggage Compartment Volume, cu. ft. (cu. M)
13.35 (0.368)
16 cu ft 15 cu ft
<a name="_Toc129085064">Suspension</a>
Front
Independent MacPherson strut, coil spring over gas-charged shock absorbers, stabilizer bar with isolated suspension cradle
Rear
Multi-link independent with coil springs, link-type stabilizer bar, gas-charged shock absorbers and isolated rear suspension cradle
<a name="_Toc129085065">Steering</a>
Type
Speed-proportional, Power Rack and Pinion
Overall Ratio
16.5:1
Turning Diameter (curb-to-curb)
36.5 ft. (11.13)
Steering Turns (lock-to-lock)
3.3
Brakes
Power assist type: All - 8 x 9 (204 x 230) Tandem-diaphragm vacuum
Standard in
SE
SXT
R/T FWD
R/T AWD
Optional in
none
SE
SXT
None
Front Size and Type
11.5 x 1.0 (294 x 26) Vented Rotors With 2.2 (57.0) single-piston floating caliper
Same
Same
Same
Swept Area (total front)
223.5 sq. in. (1442.1 sq. cm)
Same
Same
Same
Rear Size and Type
9.0 x 0.8 (229 x 35) Machined Drums
Same
10.3 x 1.39 (262 x 10) solid rotor With 1.4 (35.0) single-piston floating caliper
11.88 x 0.4 (302 x 10) Solid rotor With 1.4 (35.0) single-piston floating caliper
Swept Area (total rear)
78.1 sq. in. (503.6 sq. cm)
Same
138.6 sq. in. (894.6 sq. cm)
223.2 sq. in. (1440 sq. cm)
Parking Brake Type
Drum
Same
Drum-in-hat
Same
ABS
None
Yes
Four-wheel ABS
Same
<a name="_Toc129085067">Wheels</a>
SE: steel painted with wheel cover, 16 inch x 6.5
SXT: machined, painted cast aluminum, 17 x 6.5
R/T (optional, SXT): machined, painted cast aluminum, 18 x 7.0
R/T (optional): chrome-clad cast aluminum, 18 x 7.0
<a name="_Toc129085070">Tires</a>
SE: P215/65R16 Firestone FR690.
SXT/ SE option: P215/60R17, Bridgestone Turanza EL400
SXT Option: P215/55R18, Bridgestone Turanza EL400
R/T: P215/55R18, Bridgestone Potenza RE92A
Suppliers
ComponentSupplier
AIRBAGS
AUTOLIV
AUDIO SYSTEM EIGHT CHANNEL AMPLIFIER
VISTEON CORP.
AUDIO SYSTEM RADIOS
ALPINE ELECTRONICS, HARMANN BECKER AUTOMOTIVE, SIEMENS VDO
CALIPER
AKEBONO CORPORATION
CONSOLE
FAURECIA INTERIOR SYSTEMS
DOOR CASSETTE MODULES
INTIER
DOOR PANELS
ENGINE TRANSMISSION MODULE
ANDROID
EXHAUST SYSTEM
FAURECIA EXHAUST SYSTEMS
FASCIAS
LDM TECHNOLOGIES
FRONT END MODULE
FAURECIA
GLASS
PPG, PILKINGTON
HALF SHAFTS
GKN
INSTRUMENT PANEL MODULE
FAURECIA
MIRRORS - EXTERIOR
INTEGRATED MFG & ASSEMBLY
MIRRORS - INTERIOR
GENTEX
SEATS
FAURECIA AUTO SEATING
SHOCK ABSORBER
MONROE AUTO EQUIPMENT
STEERING WHEEL
AUTOLIV
SUSPENSION MODULE FRONT & REAR
TRW
TAILLAMPS
MERIDIAN
TIRES
BRIDGESTONE/FIRESTONE
WHEEL - ALUMINUM
SUPERIOR INDUSTRIES, ALCOA, DICASTAL
WHEEL - STEEL
MERITOR
WHEEL & TIRE ASSEMBLY
ANDROID
WINDOW REGULATORS
BROSE NORTH AMERICA
WIPER MODULES
ROBERT BOSCH
WIRING
EWD LLC
Land vehicle Vehicle Car Dodge avenger Motor vehicle
Platform
Officially, Chrysler wrote that the Sebring's JS platform is derived from the GS [Caliber/Compass/Patriot] platform but is wider and longer. Many parts are shared among vehicles on the two platforms, and a high level of flexibility has been engineered into the assembly process. If demand is strong, the Chrysler group can assemble the Sebring and Avenger at its Belvidere plant. Conversely, Chrysler can assemble the Caliber and its Jeep siblings in the Sterling Heights plant.
oh20 reported - correctly and long in advance - that the drivetrain choices are the four-speed automatic transmission with the 2.4 World Engine (40TES automatic) or the 2.7 V6 (41TES automatic; standard and flex-fuel versions); a retuned (for lower horsepower) 3.5 liter V6 is optional, with the brand-new 62TE six-speed automatic transmission developed entirely by Chrysler (which includes a special kickdown gear, technically making it a seven-speed). oh20 also reported that the ESP stability control package will be available. There are many cool features in these vehicles - see the feature lists further down on this page.
Export cars get a Volkswagen diesel and 2.0 liter four-cylinder World Engine, coupled to the automatics or to a manual transmission (a five-speed Chrysler design or a six-speed Aisin model). This is the engine in the "concept car" shown in France (and pictured on this page).
Currently, the Sebring and Stratus sedans, combined, are selling around 200,000 units per year, including the closely-related Sebring Convertible, while the Neon is selling around 120,000 units. The Sedans outsold the Mitsubishi-designed Coupes by more than a 4:1 margin when sales data was still separated.
RedRiderBob and Michigan_79 stopped the clock on a Chrysler presentation and found the Avenger!
...and they did it six months before the September photos (clearly showing the same car, in silver) arrived.
Land vehicle Vehicle Car Bumper Product
2007 Dodge Avenger features (thanks, oh20)
You may remember oh20 from the highly accurate Dodge Caliber feature lists. He's come through again.
Engines: 2.4 world engine; 2.7 V6 (standard and flex fuel); 3.5 V6. Transmissions: 40TES, 41TES, and 62TE.
Colors: silver, black, inferno red, gold, marathon blue, modern blue, white.
Interior colors: dark khaki/light gray; dark/light slate gray; beige/cream.
Base model standard features are surprisingly generous; note the standard dual horns, floor mats, keyless entry, power heated mirrors and locks, day/night mirror, cruise, side airbags, tilt-telescope wheel, and tachometer!
  • 120 Amp Alternator
  • 120 MPH Primary Speedometer
  • Two 12V Power Outlets
  • 16X6.5 Steel Wheels
  • 17 Gallon Fuel Tank
  • 2.69 Overall Top Gear Ratio
  • 2.4 liter World Engine
  • 525 Amp Maintenance Free Battery
  • Air Conditioning
  • AM/FM CD MP3 Radio (RES)
  • Analog Clock
  • Black Windshield Moldings
  • Body Color Door Handles and Fascias
  • Color Keyed Park Brake Lever
  • Cowl Mounted Hood Release
  • Dark Argent w/Bright Accents Grille
  • Decklid/Liftgate Ajar Warning Lamp
  • Dual Note Horns
  • Electroluminescent Gauges
  • Floor Console w/Fore/Aft Slide Armrest
  • Front and Rear Stabilizer Bars
  • Front Height Adjust Shoulder Belt
  • Front Rear Floor Mats
  • Front Rear Solar Control Glass
  • Front Wheel Drive
  • Grocery Bag Hooks
  • Headlamp Off Time Delay
  • Hood Insulation
  • Illuminated Entry
  • Instr. Panel Color Keyed Bezel
  • Instrument Panel Storage Bin
  • Keyless Entry
  • Low Back Bucket Seats
  • Manual Driver Lumbar Adjust
  • P215/65R16 BSW All Season Tires
  • Power Accessory Delay
  • Power Heated Mirrors and Locks
  • Power Rack and Pinion Steering
  • Power Trunklid Release
  • Quad LHD Optics Headlamps
  • Rear Armrest Seat
  • Rear View Day/Night Mirror
  • Rear Window Defroster
  • Removable Short Mast Antenna
  • Sentry Key Theft Deterrent System
  • Speed Control
  • Supplemental Side Air Bags
  • Tachometer
  • Tilt/Telescope Steering Column
  • Tinted Glass Windows
  • Trunk Dress-Up
  • Trunk Lamp
  • Var Intermittent Windshield Wipers
The next model is even better. It takes the standard model and adds:
  • 140 Amp Alternator
  • 17X6.5 Aluminum Wheels
  • 2.7L V6
  • Anti-Lock 4-Wheel-Disc Brakes
  • Automatic Headlamps
  • Frt Pass Forward Fold Flat Seat
  • Instr. Panel Brushed Aluminum Bezel
  • Leather Wrapped Steering Wheel
  • Outside Temp Display in Odometer
  • P215/60R17 BSW All Season Tires
  • Power 8-Way Driver Seat
  • Premium Headliner Module
  • Pwr Front Windows, 1-Touch,Up Down
  • Steering Wheel Mounted Audio Ctrls
  • Tire Pressure Monitoring Warning
Finally, there is a top package which adds:
  • 18X7.0 Aluminum Wheels
  • 6 Boston Acoustics Speakers
  • Auto Temp Control
  • Bright Door Handles
  • Fog Lamps
  • Instr. Panel Tortoise Shell Bezel
  • Instrument Cluster w/Display Screen
  • Leather Wrapped Shift Knob
  • P215/55R18 BSW AS Touring Tires
  • Premium/UGDO Headliner Module
  • Pwr Front Windows, 1-Touch, Up Down
  • Rear View Auto Dim Mirror
  • Security Alarm
  • Tortoise Shell Steering Wheel
The 3.5 liter V6 engine is an option only on the top model.
Options on all models are: Air Filtering, Sun Visors w/Illum Vanity Mirrors, Temperature Compass Gauge, Tire Pressure Monitoring Display, Traction Control, Smoker's Group, Traveler/Mini Trip Computer, Remote Start System, Front Drive/Pass Sunglasses Holder, Side Front Seats Air Bags, Side Window Curtain Frt/Rr Air Bag.
2000s Dodge Stratus and Chrysler Sebring. Designers' sketches (Dodge Avenger's styling evolution)
