If the timing belt hasn't been changed, it is due. I've done the job myself, but it is TEDIOUS. Figure a full day to get it done, and be sure to change the water pump, idler and tensioner while you're at it. Also, drive it and listen for front wheel bearing noise. The PTs are susceptible to wheel bearing noise, but they aren't too bad to replace. Fianlly, the lower control arm bushings can go. You would hear creaking or thumping going over bumps or up driveways, etc. I replaced mine with bushings from Energy Suspension and all is fine for over 100,000 miles.
With all of that said, the PT is a great car. My 04 has 267,000 miles on it. Original transmission and engine, and not much work done to either one outside of normal maintenance. The car itself is in great shape.
Hope this helps.
Doug
Hope this helps.
Doug
