drip rail replacement
3243 Views 5 Replies 3 Participants Last post by  dana44
I just finished sandblasting my 47 Plymouth body and as expected there are some repairs needed. I was expecting most of the damage around the bottom of the body. I had not thought about the drip rails over the doors. They are full of holes in several places! Are there replacement pieces and if so how much trouble is it to install them? Or maybe I sould just grind them off completely and fill in the gap?
1 - 6 of 6 Posts
· Registered
I would grind the areas as best as can be done, and weld the holes closed. If the holes are too big, fill in with some sheet steel patches from the top side. Less visible that way. Removing the rails will hurt the side view of the car very much.
· Registered
Discussion Starter · #3 ·
The rails are smaller in diameter than my pinky finger! If I weld them, the weld will create a lump on the inside of the tube and there is no way to grind it smooth, as the inside diameter is too small access? The lumps of weld would just cause trash and dirt to catch on them, the water would just well up and run over the side of the rail.
· Premium Member
This is going to be a fun one, but if you look at the construction, there is also metal bracing on the inside of the rails so it will be near impossible to get behind it to weld and I even think the rail itself is part of this bracing, so, if you are going to replace the rails it is going to be a matter of locating another set, or, get any rails and bend them appropriately, try to have an inch of metal above the rail so you don't have to weld in or too close to the rail, and as much meterial as possible to keep the welding beads below the rail as possible. The top side of the rail gulley is filled with a rubberized sealer, not just painted, so they last longer.
· Registered
Discussion Starter · #5 ·
Thanks there "44"... I was hoping you would have some good news for me. This car is getting more like my diet... More pain less gain.
I'll take another look at the drip rail connections. Then probably slip off into depression.
· Premium Member
Do a serious look at how it attaches to the structure. I think it is actually two pieces squished together. Two L shapes, one laying inside the other, the other folded over to form an edge. The long sides then go into the cab and the top comes down and attaches to it, the long side then becomes part of a support to the inside metal. I would check the looks of it, replace in sections vice the whole thing at once, grind/cut the old one off smooth first, use the replacement rail by welding about an inch of the sheetmetal above and below and outside edge of the rail to stay away from filling that rail with weld, grind/file smooth as necessary to get it in place. It isn't going to be a five minute job by any means, but I think you will be much happier than trying to replace the whole thing at once or removing it totally, even though that would be the easiest way to fix the problem, I agree it just wouldn't look right.
1 - 6 of 6 Posts
