1984 Plymouth Reliant plastic assembly that integrates with the grill and wraps around the front fender to house a running light holder with yellow plastic. The headlight opening is square and just to the center of the engine side is a square lens housing the emergency flasher. The whole assembly comes off with a Phillips head screw driver holding a verticle screw into the top of the grill mounting frame and 3 Phillips screws into the side running light part which are horizontally screwed into keepers provided.
