My daughter's driver side power door lock will NOT lock. It will unlock however, so I figured I needed to replace the actuator (all the rest of the door locks are working properly). I purchased one from a salvage yard, but last night when I installed it, I ended up with the same results. So I'm assuming I must have a wiring issue, or perhaps even the RKEM (remote keyless entry module)? I'm not really sure how do diagnose the problem or what to test. I did get my electrical tester out and found that when I press the "unlock" button on the door, I have power on the terminal connected to the pink with black stripe wire. I could not get anything else to give me a reading.
I'd really appreciate any help with this problem, I need direction as to what/how to test for the problem. I have some photos I'd like to post that might help, but I've not figured out how to do that yet...
