I installed the new axles and suport plate for the drum brakes. As I started to put the drakes back together, the strut would not fit. I ground off a 1/4" and it fit.
That probable was not a good idea, but to late.
After that everything went smooth, until the drum.
The drum slid on, but it went back to far against the support plate and would not let the tire spin.
Putting 1/8" thick washer over the lug nut bolt solved the problem.
I got the axles from Dr Diff. Not able to contact him until August 19.
Are there different length axles for an a-body housing? Ones that are only a 1/4" longer?
I'm not sure about the washers, is there a plate that can slide over the 4.5 bolt pattern and keep the drum from hitting the plate.
Or do I have to get new axles that are longer?
Last question if theses are the wrong axles can I keep them and install disk brakes to make this problem go way?
Thanks
Thanks
