Dumb Problem and question- '92 Shadow
2304 Views 10 Replies 7 Participants Last post by  MoparJeff
Decided to start resurrecting my daughter's Shadow that has been sitting for a few years.
Great idea until I discovered the hood latch is frozen shut. Gave the release a few good yanks but didn't want to break it.
Any good ideas on how to get it released if the cable won't do it?
1 - 11 of 11 Posts
· Super Moderator
Get someone to pound on the edge of the hood above the latch while the release is held open. Sometimes that will work.
· Registered
Discussion Starter · #4 ·
Thanks for the replies!
Had my son pumping the hood (said he felt like he was doing CPR--- how appropriate!) while I yanked on the lever until it started to bend.... no luck :(
Will keep shooting WD40 and rust penetrator in the general area and will see what the next couple days bring...... in the meantime, any other suggestions gratefully accepted :)
I do not think any of it is acessible from underneath, seems like the radiator and other structure would be in the way...
· Super Moderator
The latch, if accessible, would be from below, and in front of the radiator.
· Registered
Discussion Starter · #6 ·
OK, daily doses of rust buster (as best I could do in general area of latch between hood and fascia/grill), CPR on the hood while yanking on the handle, and we are still stuck.
If I can get to it from underneath, any tips? Cable end assembly looks pretty secure (and not enough room in there to fit a sledge hammer up there lol).
Really don't want to break anything, I have been searching the world wide web and don't see any replacement cables/handles available if I do bust it trying to get it open.
This issue and weather too cold for my old bones = AAAARRRGGGGHHH!
Thanks again for any replies and tips!
· Registered
Have you tired heat, Jeff? Now I don't mean take a propane torch to it and heat it until the paint blisters off, but maybe a heat gun. If you don't have a heat gun, then a propane torch, but not too close to the paint. Of course if the paint is crappy anyway, it won't make too much of a difference, will it?
· Super Moderator
Sometimes the mechanical shock of a fist thump will do more than pushing up and down on it.
The latch can be actuated manually from underneath if needed with a long narrow flatblade screwdriver.
· Registered
Sounds like all you guys have been there before! As a last resort, I've made sure I could replace the grille cheap from a pic a part and just smash the old one out to get to the hood latch and unbolt/cut/pry/whatever..... Much easier to work with without the grille in the way.
1 - 11 of 11 Posts
