1986 LeBaron convertible, 2.2L T2 with A413. 1989 J convertible dash and console modified to fit.
Does anyone on here have any expertise on the 80s vintage electronic dash units. Maybe someone with any type of schematic? I have a bunch I bought cheap from someone who wanted them gone and I know the 5 4312654 ones (1984-87 G body) all need the push button switches replaced. The other 5 are the full vacuum fluorescent ones (4312851) from 1988-89 G bodies and 1987-89 J bodies all display FAIL 2 in the initial test.
Further diagnosis points to it being the gas gauge circuitry as grounding the #21 pin (natural connector) gives no response from the gauge (it still shows empty). Oil pressure gauge will go full scale with this. Oil pressure (pin #5 (black connector) shows 9 VDC open circuit, gas gauge pin shows 5 VDC open circuit. I didn't check the temperature gauge circuit (pin # 9 black connector).
I would like to get the mating plugs if someone has some old harnesses they are cutting up for parts. they are 13 pin black and natural colored plugs. I could also use a 21 pin black and another 13 pin blue as that is what the older electronic clusters used along with a green 7 pin for the pull up resistors (same as the radio plug).
