i assume you mean the upper and lower engine mounts on the passenger side. It is not uncommon for these to fail. The measurement is done on the upper mount, using a hole near the suspension strut mount as the reference. Be sure sure you measure between the correct points, but other than that, adjusting is not difficult with a floor jack.
