This is a '02 Dodge Grand Caravan Sport with 3.3L V6 and 92k miles.
Recently replaced trannie filter (Wix) and fluid (ATF+4), belt with tensioner and idler pulley, alternator and water pump, idle air control motor and spark plugs/wires.
Engine runs strong but has started to stall at startup when cold/wet. Starts right up but there is something happening when it is cold/wet outside.
I have replaced the throttle position sensor once already. Is that a wear item?
Any other candidates?
Recent tune-up with spark plugs/wires and IAS motor was because it was stumbling at idle.
