1 - 5 of 5 Posts
The repair manual I have is only for the standard Van, none with Dually's.
I have a Chinook Motorhome that of course has dually's and need the diagram to do some maintenance.
Either that or a name of a web site to find it.
Thanks in advance.
Thanks in advance.
This might be of help. Not exploded but a lot of info.
1) You have a floating axle that comes out first
2) Axle bearing nut releases the bearings.
1972-1993 Dodge Van and Motorhome Dana 60 Rear Wheel Bearing Applications (at https://torqueking.com/1972-1993-dodge-van-and-motorhome-dana-60-rear-wheel-bearing-applications/ )
This is a service manual on a CD from eBay. Information like this has to be thought of as a tool that will pay for itself, many times the first time you use it. (I have not done business with this seller).
Typically, exploded views are shown in the parts catalogs. If the diff fluid hasn't been changed, it is due. A 75W-140 synthetic?:
KOG
I've got a dually axle from a cube van under a cut down B300 7' flatbed/ I seem to remember that it's a 70 as opposed to the 60 on the 1T vans. All service procedures are identical to the 60.
1 - 5 of 5 Posts
