facel vega chrysler.
5080 Views 10 Replies 8 Participants Last post by  saltydog
Hi there,
I am Willem from the Netherlands currently driving and enjoying a 1960 Facel Vega HK500.
These rare french handbuilt cars were originally equipped with chrysler engines.
So there's the reason to join the forum because I think it is allways good to get to know more about your engine.
Happy to be here.
1 - 11 of 11 Posts
· Super Moderator
Welcome to Allpar. These prestige cars were rare over here in the US then and even rarer now. Another interesting application for the Hemi engine in a special body.
I think that I've only seen one in person.
http://en.wikipedia.org/wiki/Facel
· Registered
Hi all,
I am Philippe from France, known on the web as "Robert Gel" in the "Facel Vega's World enthusiasts". Robergel is the type of wheels mounted on the Facel Vega until 1958.
I own a 58 Facel Vega HK 500, with 383 cid dual Carter carbs and a Pont à Mousson manual Gearbox.
It is a pleasure to drive and maintain this car.
Lots of mopar engines were fitted on the Facel Vega cars.
Hemi Engines until 1958 (392 cid).
And you are lucky, because almost 75% of these cars were exported, mainly to the U.S. :)
Excuse me for my bad english. :rolleyes:
· Super Moderator
It is refreshing to see a new interpretation of the 'Forward Look' as it moved forward into the 1960's.
Exner's, Engel's, Ghia and Pininfarina cars are all beautiful styles in their own way, but this is something that captures a European style that is different.
The Pont à Mousson gearbox was an optional gearbox on the mighty 300 of this era. Most were Torqueflite.
The British Bristol cars with the Chrysler V8 were also interesting cars.
· Registered
Dave said:
Yup! http://www.allpar.com/cars/adopted/facel-vega.html
Can you send some photos? Our story has none. Interior and exterior would be great.
Some informations about Mopar engines and transmissions that were used for Facel Vega cars :
Since february 55 : Car type FV, hemi engine DeSoto Firedome S19, 276 cid, 170 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Powerflite 2 speeds, Ball & Ball carb.
Since march 55 : Car type FV1, hemi engine DeSoto Fireflite S21, 291 cid, 200 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Powerflite 2 speeds, Ball & Ball carb.
Since september 55 : Car type FV2, hemi engine DeSoto Fireflite S21 and S24, 291 cid, 200 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Powerflite 2 speeds, WCFB carb
Since march 56 : Car type FV2B, hemi engine DeSoto Firedome S23 then S24, 330 cid, 250 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Powerflite 2 speeds, WCFB carb
Since november 56 : Car type FV3, poly engine Plymouth Hy Fire P29, 277 cid, 200 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Powerflite 2 speeds, WCFB carb.
Since september 57 : Car type FV3B, poly engine Plymouth Fury P31, 301 cid, 235 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Torqueflite 3 speeds, WCFB carb.
Since may 57 : Car type FV4 (also called FVS), hemi engine Chrysler Firepower C300B, 354 cid, 340 hp and after hemi engine Chrysler Firepower C300C, 393 cid, 375 hp, manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Torqueflite 3 speeds, 2 WCFB carb.
Since may 58 : Car type HK 500, Wedge DeSoto Adventurer LS35, Fireflite LS3H, 361 cid, 360 hp, , manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Torqueflite 3 speeds, 2 Carter AFB carb on Manual trans, 1 Carter AFB carb on automatic trans.
Since January 60 : Car type HK 500 and after HK2, Wedge Plymouth Golden Commando pack police, 383 cid, 360 hp, , manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Torqueflite 3 speeds A488 and after A727 for HK2, 2 Carter AFB carb on Manual trans, 1 Carter AFB carb on automatic trans.
Since december 61 : Car type HK2, Wedge Chrysler/Dodge 413 cid, 360 hp, , manual transmission Pont à Mousson 4 speeds, automatic transmission Chrysler Torqueflite 3 speeds (A727), 2 Carter AFB carb on Manual trans, 1 Carter AFB carb on automatic trans.
For Excellence cars (58-64), same type of configuration than FV4 (392 cid), and after than HK 500 and HK2, (361,383,413).
1 - 11 of 11 Posts
