1 - 5 of 5 Posts
Im having an issue with install of a android stereo 10 incher and cant find the acc wire to hook up to,..ive cut the original harness stupidly but have all hooked up except an acc , instead i hooked it to my other constant wire, but its runng stereo really hot,..can any one help please?
Running hot = short circuit, so until someone can give you the correct wiring, disconnect that power or you may damage the radio and/or van.
You haven’t mentioned what vehicle. So no one can give you any specific wiring information.
You may have 2 battery power wires going into the radio. The radio is turned on and off by the PCI communications bus.
1 - 5 of 5 Posts
