Ebay appears to only have ONLY the 2005-10 straight line (lineal) design? The connector looks the same? but is it really?? Anyone swapped this previously? (Responses requested. Thanks)
I'm all for buying a whole new line as I'm shaky about clamping the 58psi gas lines like I did in the 05 fuel pump module swap. Those lines were 7mm and not subject to the !EXPLOSIVE! environment of the engine bay.
I've also saw that what looks like a Taco Bell on the fuel connector at the firewall. This turns out to be a "accumulator", a sort of crude particle drop off point in lieu of real fuel filter. This lazy "fuel filter" has a bad reputation especially in the Neons w our 2.4L setup. If you smell gas in your engine bay this "bad hombre" probably looks wet to the eye. Replacement at 200K may be wise too.
Can't wait to tell you of my timing belt experience. If I ever finish?, it'll most likely be in book form.
