Five ways to make a 100,000 mile car feel new again
No one is buying a new car any more, it seems. Unless you pay
cash, no one's going to lend you any money, so keep your old car. Of
course, I'm talking from the point of view of a repair shop, so keep the
source in mind. Mwah-ha-ha and hugs to you all! But
seriously, having seen lots of cars worth keeping well over 100,000 miles, as well as
those whose owners have no choice but to keep them, we've compiled a list of
ways to make that older car feel like it used to when it was new.
Number 5: Flush every fluid, even those you forgot about.
5
When was the last time you flushed your power steering fluid? Chances are,
you didn't even know that was supposed to be done. Power steering fluid is
petroleum based, with certain additives, and like any petroleum product will
break down and lose effectiveness over time. Power steering parts include
hoses, a pump, several seals, and many moving parts and metal parts and
rubber parts, all of which rely on lubrication from the power steering
fluid. Flush the power steering fluid and add some extra boost to it, such
as Lucas Power Steering Tune-Up, to give your older system a little more
help.
Flush your brake fluid - you should be doing this every other year
anyway. Again, the system has a pump, hoses, seals, moving parts, metal
parts and rubber parts, and all rely on lubrication and the presence of the
fluid to function. Over time, the fluid becomes contaminated with air,
rubber particles, metal particles, and loses its effectiveness, and we all
know what that means. It's your BRAKES. Your BRAKES! The things that keep
you from crashing into other things. Brake fluid is cheap, most places will
flush it for around $60 including parts and labor, so put fresh fluid in
your brake system every other year.
Then there are the things you already
know about - your motor oil, your transmission oil, your antifreeze, your
differential fluid. You should be doing that anyway, but definitely pay
attention to your intervals even more closely when you hit 100K.
Number 4: Straighten or replace your wheels
4
You have forgotten how your car used to ride. Gradually, over time, your
wheels have taken a lot of shock and have shown the evidence of wear and
tear. Alloy wheels are somewhat soft and will give in places, and balancing your tires often compensates for a good bit of that, but the subtle
differences will all add up to a lower quality ride.
Call a service that
straightens and welds wheels, and have them straighten and fix all the
little ouchies and boo-boos on your wheels, then have your tires re-mounted
and have everything balanced by a shop that does road force (rolling
resistance) balancing. You won't believe the difference this will make in
the quality of the ride and the comfort over all kinds of surfaces.
Number 3: De-odorize your air conditioning
3
I bet you didn't even know you could do this. Know what it is like, when
you've come out of springtime, and you get that first shock of a hot day,
and you turn your air conditioning on, and you get blasted with that smell
of mold and chemicals? Yeah, it might give you a brief feeling of nostalgia,
but you don't have to experience it that way. Find a place (might be a
detail shop) that does de-odorizing of the a/c system.
The vents, cabin air
filter (if equipped), and vacuum system get cleaned, mold killed, and a
pleasant smell emitted in its place. The drain tubes (bet you didn't know
you had those, either) get unclogged (they are clogged, I promise), cleaned
and disinfected, and deodorized. Want a cheap way to do it yourself? Find
where your cabin air filter is, change it yourself, and spray it down with
Febreeze before you put it in. Then start your air conditioning, and spray a
disinfectant into your cabin air intake (usually located at the cowling)
until you can smell the disinfectant in the cabin of your car.
You can also
unclog the drain tubes yourself, you just need to find them. Wear rubber
gloves for this, trust me. That buildup of mold, rust, outside contaminants,
allergens, and other airborne ickiness is what gives your car that old-car
smell. You can go a long way if you can de-odorize it by having it suck in
fresher air into a fresher system.
Number 2: Replace your struts/shocks and ball joints (as equipped)
2
Save up and take the plunge and do this all at once. I know, nothing is
broken, I know, they seem fine, I know, it's expensive, but you won't
believe what this will do for the way the car handles. Your safety, your
comfort, and your love of the ride will improve. Tightening all these items
up adds up big. You won't believe it the next time you get in the car and
you find your stopping distance has SERIOUSLY decreased, you are stopping
smoother and with less effort, and with less noise and rocking back and
forth. You won't believe how gentle you can be on the accelerator pedal and
have the car respond better than you ever remember. You won't believe how
suddenly it seems like you have a tighter turning radius (you don't
actually, it just feels so much smoother that you turn with more
confidence), and the car throws you around less when you turn hard or turn
at a faster speed. For less effort, and less wear and tear on all the moving
parts, your car will stop better, accellerate better, turn better, and
overall ride better.
Number 1: Replace your catalytic converters, muffler and oxygen sensors
1
Again, do it all at once. I'll give you an example. I have an SUV with 4
oxygen sensors, 3 catalytic converters, 2 turtle doves, and one muffler.
After having to constantly battle the check engine light starting somewhere
around 100K, and fighting the diagnosis that I needed oxygen sensors, I put
it off for a while. Sure, you can run an emissions system cleaning and keep
putting it off. Or, you can just replace the oxygen sensors that your check
engine light is whining about. But that crap will keep building up in your
system, and as your catalytic converter(s) start to deteriorate, they start
to break down, parts start to peel off, and travel downstream into your
muffler where they remain trapped in the sound chambers. Forever. To clog
the system.
No engine can have the power it once had if it is pushing out
exhaust through narrowing pipes. Think about your heart and your arteries.
No matter how hard your heart pumps, if your arteries are closing in, you
won't get the benefit of strongly pumping blood. Same with your exhaust
system.
Your engine wants to be powerful and efficient. Clog it up, and
don't let the waste (exhaust) out, leave the exhaust to just putt-putt on
out of there, and you lose power and efficiency. Your oxygen sensors will
always read wrong because of the contamination of the backing up exhaust,
and so the engine will always think the fuel flow is wrong, and will keep
dumping fuel, and how you liking that when it's $5/gallon gas?
So, anyway,
back to me. After fighting what I knew I should do for a year and a half, I
took the plunge and replaced it all at once. Immediately, on my first trip,
I saw a difference. I have a relative on the other side of the state.
Usually I could leave my town on a full tank of gas, travel to his town,
drive around a little, and be two-thirds of the way back before I needed to
fill up for gas again. Right after giving my exhaust system an enema and a
new plumbing system, the very next trip I went to see him, drove around,
went back home, and had a quarter of a tank of gas left in the tank when I
got home. Since then, since I have been preaching this and showing customers
the difference, the ones that have taken my advice have seen the same
results. You just get a buildup in your exhaust system over time, it just
makes sense, and cleaning it is not enough. Replace it and you will find
your engine runs cooler, runs faster, runs better, is far more efficient,
and you will save money.
(Kidding about the turtle doves. Has anyone even seen one before? But I meant it about the other stuff.)
While it is true that I have an interest in you keeping your car longer, I
also want you to be happy with your car. The more you like it, the better
that is for me. If I give you bad advice, you won't be back to see me, so I
am careful about the advice I give. And if you are stuck with your car and
have to keep it, you might as well enjoy the ride. These are the best ways I
can think of, and that I can prove, will most improve your enjoyment of your
older car.
-Beth
Chrysler dealers and car repair shop articles
