Does anybody know what this door pin part is called?
Last night I tackled my broken (93 Acclaim) door handle, I took off the door panel to discover why it was loose and didn't reset its' position.
On the plastic handle mechanism there is a small hole on top, followed by a thicker hole on the bottom where a 'pin' is inserted. This 'pin' is used to hold the handle and spring in place, and I believe my 'pin' may be broken.
Top of the mechanism
The pins' base is thick, and appears to be inserted into the lower hole, however since the top hole is smaller, it leads me to believe the smaller tip to my 'pin' may have been broken sometime in the past 20+ years.
Bottom of the mechanism
I'm not really sure what this 'pin' part is called, or if my idea of how the mechanism works is correct and could use some help. There aren't very many Acclaims in my area, but there are plenty of 90s Lebarons, so is it possible for me to source this part from one of those? I ordered a 1994 factory service manual to discover more, but it hasn't arrived yet.
Thank you very much in advance!
