Flexible manufacturing at Chrysler
Architecture is the type of body built - two door sedan, four door sedan, station wagon, minivan, convertible, etc.
Architecture does not refer to specific parts sharing, but the second grouping of two letters in the body code (not used in the VIN) specifies specific trim levels, which are groups of parts.
A platform only define the space required to assemble the parts and nothing more.
A chassis is only the structural parts that attach the suspension, brakes, powertrain, steering, fuel, and ride control systems to the body.
- Bob Sheaves
Flexible manufacturing is, in its essence, the capability of making different vehicles on the same assembly line without long delays to change tooling. In practice, it is now possible to make completely different vehicles on the same line with no delays to change between vehicles.
The way this works is by extensive use of robots and computers; the robots have tooling or spot welders on the end of their "arms" and when a new vehicle comes down the line, they can quickly swap to different tooling or welders, and apply their arms in different ways. This also works in the paint shops, where robot arms are programmed to act differently depending on the vehicle that shows up.
This requires more flexible robots with computerized programming and networked communications, which is one reason why flex manufacturing was not practiced much in the 1990s (when cars were assembled almost entirely by hand, flex manufacturing was also possible and was moderately common, but it could easily lead to quality gaffes, where the wrong parts were applied - e.g. Dodge labels to Plymouth cars or mismatched right and left side mirrors).
In addition to network communication, barcodes or RFID (radio frequency identification) tags can be used to tell the machines what model is coming down the line.
The primary requirement for using flexible manufacturing is the ability for different vehicles to use the same carriers (or having multiple carrier types); as bluecon wrote, there are usually four points where the carriers carry the body until tires are installed, and the vehicles is put onto a flat track. If these points are carried over from body style to body style and there is enough clearance in the carrier (or in the case of welding, you have the jigs and end tooling for the part) you can produce many different models and styles.
Bob Sheaves noted that platforms are defined as common dimensions between various "top hats" and "architectures" (collections of hard parts), so that various completely different vehicles can be built within the same physical space allotted to the vehicle carriers.
rapidtrans wrote: "You have to see a flexible body shop in operation to truly appreciate the advantage over the old style body shop. You do away with those large fixtures or jigs that could only assemble one part/vehicle each. With flex manufacturing a robot can be programmed to assemble and or weld say a Caliber quarter panel followed immediately by a Compass quarter panel then a Patriot quarter panel. One robot can hold the part while a second welds the piece even if the part is in motion. You can build completely different vehicles sharing the same architecture, one after another, with just a programming change. Robots are strong enough now to handle an entire body at full reach.
"When the new model changes, the software is simulated and then downloaded to the plant-floor robots with no need for expensive fixture rework or replacement.
We can do robot motion simulation without ever seeing the actual part/vehicle in the flesh. The CAD files are used to assemble the vehicle on my computer and run the simulation at my desk."
Stratuscaster noted some of the advantages:
Chrysler Plants
CTC (HQ)
Proving Grounds
All Facilities
Flex
Labs
Techs and Workers
Allpar Home
Home •
Engines •
Reviews •
Chrysler 1904-2018 •
Upcoming •
Trucks •
- Bob Sheaves
- Competition has greatly increased, and while 100,000 units are still needed to recoup engineering expenses, it's harder to sell that much of a single vehicle. Creating multiple models lets more designs/vehicles can carry the load (and reduces the risk of a single bad styling decision bankrupting the company). So as long as the numerous vehicles on that platform can total 100,000 units in sales in a year, the goal (and costs) are met.
- Flex can allow vehicles that aren't completely similar (differing wheelbases, number of doors, etc.) to be built on the same line without stopping production to change out tooling - the tooling accomodates the vehicle instead.
- Once a vehicle is design to take advantage of the flex system, the time it takes to get that vehicle to market is reduced.
- Should one flex vehicle "take off" in sales, the number of those vehicles produced can be adjusted on-the-fly.
- If one vehicle really takes off, that vehicle can be built in another plant that supports that flex. For example, lets say the Avenger becomes incredibly popular. They could build more of them at the Caliber/Compass/Patriot plant, because the flex systems are similar.
- The investment in flex was started long ago, this isn't just some new-fangled thing. We are just now seeing the fruits of those investments coming to light.
Chrysler Plants
CTC (HQ)
Proving Grounds
All Facilities
Flex
Labs
Techs and Workers
Allpar Home
Home •
Engines •
Reviews •
Upcoming •
Trucks •
