Please help me fix this wet carpet problem. 1994 dodge caravan 3.0, last year, I started seeing front carpet both driver and passenger side wet, so I pulled the a/c/heater box out from the van because I suspected that the heater core was leaking again.
For a while, many weeks past the carpet dried up then got wet again when it rain even while the a/c /heater box was still out of the van and the van being parked for many weeks, without driven anywhere.
I searched here for an answer to my issue, found something about 97 Voyager, "The cowl drain hoses underneath the wiper box are probably plugged with leaves....".I then removed the cover that goes over the wiper cowl to clean out leaves and debris, I did not see any drain hose or any hose anywhere there..
Does this van has the same drain hose or a different drain system? I installed the a/c heater box back in the van few months ago and yesterday after some heavy rain, the front carpet is wet again both side especially passenger side.
How can I fix this wet front carpet problem? Please help me ,I really want this fix as soon as possible,thanks.
Felix.
Felix.
