When i fill the transfer case with fluid it ends up leaking out the drive axles. i only fill it to the point where i can feel the fluid just below the fill hole with my finger. Why is it leaking out of the axles?
I guess I assumed he meant the differential case.55fargo said:How does the oil get from the transfer case to the front axle?
I'm sure that's what he meant. Not a big deal here as everyone probably assumed correctly but in other cases the wrong terminology could result in wrong advice being given which in turn could lead to disaster.TWX said:I guess I assumed he meant the differential case.
If that is wrong, then I don't know how the heck it could be leaking as actually described...
