Does anyone know what the part number is for the plastic/rubber strip as described on this Allpar page: http://www.allpar.com/eek/repairs.html
"Power windows (Dan McGuire): If the window has problems going up and down or falls into the door, you need to replace the rubber/plastic strip; it’s available at the dealer and costs around $30. It only takes about twenty minutes to put it in. Take off the door panel, unbolt the end of the broken strip from the window and run it past the end of the track. Take the broken bits and use them as a guide to cut the new strip to the right length, then feed the new strip onto the track, bolt it to the window and put the door panel back on."
