What will it buy you? It will either run richer than intended, or the computer will scale back on its performance so it won't run too rich.
Is there part numbers I should be looking for? or looking out for?There is a possibility that you have the 34.85 lbs/hr injector in your car already. There was a mid year change in 88 from the 27 lbs/hr injector to the 34.85 lbs/hr injector. So buying the 804 injector may net you nothing.
Not necessarily. An adjustable fuel pressure regulator can be used in lieu of custom computer. The factory computer will also run the injectors too, albiet very rich.If he were to switch injectors then he would also need a different computer or custom cal - correct?
