Supply is 5/16" inside diameter; return line and vent lines are both 1/4". Don't mix up the two when connecting. And use only SAE rated 30R9 or 100R6 hose, not 30R6 or 30R7. The latter two are not rated to withstand the pressures.
I'd be careful of using 2 feet of rubber hose there. It should be secured well and protected against abrasion and stones. That will be hard to do in that area.
