Get Engauged: So you think your oil pressure doesn't fluctuate?
By Richard Ehrenberg. Copyright © 1999 Richard Ehrenberg and Harris Publications. Photos by Richard "Eastman" Ehrenberg. Used by permission. First printed in Mopar Action
We're always amazed at the percentage of old Mopars cruising around with a can of gas in the trunk. Nine out of ten times, it's because the fuel gauge is shot and nobody's quite sure how to fix it. The instrumentation in muscle-era Mopars wasn't a model of accuracy, even when new!
This repair deals with what the manuals used to call the voltage limiter - what we now call the voltage regulator - for the dashboard and gauges. The term "voltage limiter" is no longer in common use. - Editor
Spend enough seat time in Vern's '68 Road Runner (the one where the quarter panels wave back at you) and you'll likely see all the gauges "pin" at least a few times. And, even if not, you'll surely see 'em slowly drift up and down in unison.
A second common minor hassle has driven a fair share of Mo'guys to grab for another Bud: there you are, siting with your main (or side) squeeze, listening to oldies on some AM radio station. But click....click....click, every second or two, there's this annoying noise pulsating from the dryrotted six-by-nine. Jeez, what could be causing that?
90% of the gauge-related maladies are related to the fact that the reference voltage that the gauges rely on is really not very stable. The ancient electromechanical regulator was pretty poor when new, and now that it's 40+ years old...well, you've seen the results. We have a way-cool computer-era way to solve this problem permanently, for under five bucks, and we'll show you how to diagnose other stock-instrumentation maladies, and make some other easy improvements as well.
GIBRALTAR: the original Chrysler gauge design
Virtually all Mopar RWD passcars used thermal-type instrumentation (shown at right). The pointer of each gauge (excluding the ammeter, of course) was mechanically linked to a bimetallic strip, wrapped with resistance (heating) wire, just like old toasters. As the current passed through this wire increased, the wire got hotter, so the bimetal strip bent more and more, deflecting the pointer.
As you probably guessed, this gauge design is well damped and slow to respond - which is probably a good thing. Nobody wants to see the gas gauge, for instance, swing wildly as the fuel in then tank sloshes around. The designers were just as happy that Vern can't see the temp gauge fluctuate as the thermostat opened and closed, or the oil pressure dropped down to 20 PSI in traffic on a hot day.
One end of the Nichrome (resistance) wire is connected to the sending unit for that particular gauge: a thermistor (temperature-variable-resistance solid-state device, see above) in the case of the water-temperature gauge; a simple variable resistor linked to a float in the example of the gas gauge (fig. 2 in the photo section), and a variable resistor linked to a diaphragm in the case of the oil gauge ("A" in fig. 4, photo section.) (Cars without an oil gauge have a warning light, which is activated by means of a switch - "B" in fig 4).
The other end of all these gauges need a reference voltage supply - something rock-steady and unwavering. If this voltage varies, so will the gauge readings. Take a look a the crude regulator in figure 6. This relic of the 1930s is all that's there for your gauges to work off of. It's junk!
Now look at the tiny silicon chip at right. This tiny 50-cent gizmo can do the same job, but much more reliably and "solidly." That clicking noise ol' Vern heard on the radio was the points in the
regulator opening and closing. The theory was simple: if 5 volts was required (the number, in our case), and the battery was at 14 volts, the regulator points would need to be closed 5/14ths of the time, or, phrased another way, 36% duty cycle. So on, off, on, off it slowly clicked! Crude, and not terribly good at what it was supposed to do.
The silicon chip takes that fluctuating input and, through the miracle of solid-state technology, produces a rock-steady 5 volts. Figures 7 though 14 will show you how easy it is to trash that old mechanical junk and be up to Y2K speed.
ACCURACY: reference voltage
Once the reference voltage is made rock-steady, you can shoot down any other single-gauge problems. Usually this is just a case of being sure there are no corroded connections anywhere in the circuit, and no loose ground screws on the circuit board (if so equipped). The senders can be checked with nothing more than a simple multimeter. Most problems relate to the fuel gauge sender, which should read 61 to 85 ohms 'empty', and 8.6 to 10.6 ohms 'full' If the sender is within these specs, the ground at the tank strap is in place (fig. 2), and the wiring, right up to the gauge, is okay, then the gauge itself is shot.
UPGRADES: oil gauge and warning light
Many upscale Mopars of the muscle era had a factory oil pressure gauge, using sender "A" in fig 4, while the more utilitarian models used a simple switch ("B") to activate a warning light on the dash. Despite all the jokes about the light, in many cases, it's the better deal - because it's quicker to respond; it also grabs your attention instantly. Aftermarket switches are available set at 20 PSI (as compared to the stock 8 PSI) to give even earlier warning. You can also plumb in both senders, as was the case (stock) on many of the 80s turbocars (fig 3). Even neater, a new 2-in-one sender ("C" in fig 4) is available which performs both the gauge and lamp functions in one compact unit. See fig 5 for pinout info.
If you have a stock gauge now, add a simple red light somewhere where you can't miss it. Wiring's simplicity itself: One side of the lamp to switched +12 volts, the other to the single terminal on the switch.
While these upgrades and tweaks may not bring your cockpit up to space-shuttle specs, at least when a gauge shows something awry, it will be believable!
Photos and Captions:
1. Stock gauges of the muscle-era operate on the same principle: As more current flows though the particular gauge circuit, the heating wire wound around the bimetallic gauge arm heats up, deflecting the gauge. Crude, rugged, and cheap. (The ammeter is, however, magnetic). |
2. The fuel sender is the most fragile and often-fritzed part. A variable resistor and mechanical wiper change the resistance, and, therefore, the current flow though the gauge. Repairs are usually fruitless, the resistance wire itself just wears out. Find a NOS or repro! Removal is by twisting the locking cam ring counter-clockwise with a punch and small hammer. |
3. The factory's way of accommodating both an oil pressure gauge and warning lamp was, for years, a plumber's nightmare - and an invitation to leakage. Many car owners, yours truly included, have concocted something similar. |
4. Oil senders have been either the "dome" unit (A, 4051686) for a stock oil pressure gauge, or a simple 8 PSI switch (B, 4169629) for a warning lamp. The aftermarket has 20 PSI switches, which are "early warning" devices and a great idea - as is an aftermarket mechanical gauge. If you want to keep your stock gauge and add a big red bulb, something new - C, 53030493 - will allow you to have both. |
5. This photo shows which pin is which on the dual sender (53030493.) For the connector, you'll need to visit the boneyard or auto parts store. [Michael D. Griffin wrote: The pigtail is at Parts America (Schuck's, Checker, Kragen, and Advance Auto) as P/N S727. This number will yield four different Parts America items.] |
6. This item, also seen in figure 7, is the cause of most "dead gauges" and "pegged gauges" problems, as well as causing wide swings of the needle when there's no true change. It has to go! |
7. Most Mopar clusters have a printed circuit board; then the regulator simply plugs in. Very few have the regulator integral with the fuel or temperature gauge; to upgrade these, you need to remove the regulator section. This requires some creativity, but it's not difficult. To begin the conversion, toss the stock regulator, and, if present, the old metal-case suppression capacitor. |
8. Some other clusters (E-body is a prime example) have no circuit board - just a mish-mash of gauge-to-gauge and gauge-to-regulator wiring. These setups are very easy to modify. |
9. The stock regulator, item #1, is replaced by a small silicon chip (#2) in the industry as a "7805". The version we need is 5 volts, 1.5 amps, positive. This is common and cheap. We used a Texas Instruments #UA7805C, from Digi-Key Electronics, and their stock number 296-1974-5-ND. A small electrolytic capacitor, any value from 5 to 100 uF, is also needed, with a voltage rating of at least 15 volts (more is fine). We used Digi-Key stock number P5999-ND, which is 10uF @ 100V. Its purpose is to protect the chip from voltage spikes.
Remember, you only need one of these! |
